Error dimension Message
Hi, I can't understand why I always get this error message (see photo), the printer is a Caribou Prusa MK3S and I think it is configured correctly, the prints are excellent but I would like to understand the problem of the message Thanks
  • It is because you are using PrusaSlicer with default config. As you see the prime line is extruded at y = -3 but you defined your bed starts at y = 0, so -3 is not on the bed. So change y min and in bed shape also bed y min to -3 and the message will not appear any more.
  • If I understand these are the variations in the photos?
    So are they correct?
    Thank you
  • Yes, this should be correct
  • Many Thanks.
