Printer Control view, freezes in phones.
in Bug Reports
Printer Control view, freezes in phones. I think this are related to an excessive draw lines in live view witch complex layers.
Do you think you could do something about it?
There is currently no way to reduce this usage.
Generally the problem is I use the control tab without print active and all is fine, but when I will go back with a print active this will be the default tab and freeze this and other tabs for this printer.
Maybe view only the red dot with the nozzle position without the full path of the layer may help.
