"stray '\357' in program" type errors in Eeprom.ccp
Discovered when using: Repetier-Firmware configuration tool 1.0.4 the Eeprom.ccp is encoded as UTF and Arduino does not like the resulting characters, to resolve this load Eeprom.ccp into Notepad++ select the all the text (ctrl+A) then select Convert to ANSI in 'Encoding' - save and enjoy
  • Thank you, nearly racked my brain looking for solutions. I knew it wasnt my error
