I am trying to get this working and I see an option for E3D PT100, I select this and pick analog pin 3 and connect the signal from the amplifier board. What am I missing?
I am using an Azteeg X3 Pro and I am using A3 as the analog intput which is a standard analog pin, and giving the card from E3D 5V and GND. when I select E3D PT100 the temp starts at the correct temp (20ishC) but when you turn on the heater the feed back climbs to exactly 80.0C and stops even thought the temp continues to rise, I then turned off the heater and temp goes down after it gets below 80.0C.
Thanks for the feedback. I double checked the temperature curve and there was a error at the beginning. I guess that caused the wrong readings. Please try with the updated version and report if it now makes more sense.
Ok, I will ASAP. (November 5th) Can you post the section of code you changed?
