DEV2 not compiling with default_envs = skr_mini_e3_v2_0
When I tryed to compile dev2 (https://github.com/repetier/Repetier-Firmware/commit/5ccc18ad0790f21979d6387f0fcc482c69aa4083) without adjusts, its finalized OK. But, when I changed default_envs = skr_mini_e3_v2_0 in platform.io and #define MOTHERBOARD MOTHERBOARD_E3_MINI_V2_0 in Configuration.h, I had compile failure:
In file included from src/boards/pins.h:121,
                 from src/Configuration.h:171,
                 from src/Repetier.h:302,
                 from src/PrinterTypes/PrinterTypeCartesian.cpp:19:
src/boards/STM32F1/HAL.h:141:34: error: pasting "GPIO_" and "-" does not give a valid preprocessing token
  141 |             LL_GPIO_SetOutputPin(GPIO_##port, GPIO_##port##_MASK); \
src/boards/STM32F1/HAL.h:157:23: note: in expansion of macro '_WRITE'
  157 | #define WRITE(pin, v) _WRITE(pin, v)
src/io/io_output.h:57:17: note: in expansion of macro 'WRITE'
   57 |                 WRITE(pin, 1); \
src/Configuration_io.h:52:1: note: in expansion of macro 'IO_OUTPUT'
   52 | IO_OUTPUT(IOE2Step, ORIG_E1_STEP_PIN)
src/boards/STM32F1/HAL.h:141:47: error: pasting "GPIO_" and "-" does not give a valid preprocessing token
src/boards/STM32F1/HAL.h:143:36: error: pasting "GPIO_" and "-" does not give a valid preprocessing token
  143 |             LL_GPIO_ResetOutputPin(GPIO_##port, GPIO_##port##_MASK); \
src/boards/STM32F1/HAL.h:143:49: error: pasting "GPIO_" and "-" does not give a valid preprocessing token
src/io/io_output.h:59:17: note: in expansion of macro 'WRITE'
   59 |                 WRITE(pin, 0); \
compilation terminated due to -fmax-errors=5.
  • If course not. The mini has much less pins and several pins used in the sample config do not exist for the e3 mini.
    Always if you see something like
    think first that you are trying to use a pin name that does not exist. If you look into error development further down you see
    So that comes from using ORIG_E1_STEP_PIN which is the step pin for second extruder and that board has only 1 extruder. So reduce NUM_TOOLS to 1 and remove all references to second extruder from configuration. Then it should start to compile.
    Increrible, that works! Tks!
