Radds is working fine on V2. Board is not that important - just use a config that matches your printer type and adjust board type. Felix Pro 1 is what most might use except that it has unusual filament jam detection and adjustable bed with 2 extra steppers. So these parts should be removed in most cases.
Stacker X1 might be the better alternative config. One extruder and simple filament detection.
Do you have a config file i can see? I cant get mine working.
