configuration.h for due/Radds
Hello,
i switched from repetier to klipper and now i am curious about repetier V2.
Does anyone with and due Radds combo use V2 ? Maybe you can share your firmware ?
Best regards
Chris
  • Radds is working fine on V2. Board is not that important - just use a config that matches your printer type and adjust board type. Felix Pro 1 is what most might use except that it has unusual filament jam detection and adjustable bed with 2 extra steppers. So these parts should be removed in most cases.
    Stacker X1 might be the better alternative config. One extruder and simple filament detection.
  • I did the conversion on radds / Due + Radds extension+ motorized bed leveling, z-Probe.
    Still questions?
    Still questions?
    Do you have a config file i can see? I cant get mine working.
  • edited August 2021
    configuration.h + Configuration_io.h:
    do you have access?
    regards,
    Steve
