Update from 1.0.4 to 1.1.0 (locale::facet::_S_create_c_locale name not valid)
Hi.
I initiated the update from Web UI to the latest but it was doing it and doing it, restarted the RaspPi.
Then tried installing it from ssh by downloading and installing Repetier-Server-1.1.0-Linux.deb
But still, the service won't run and web UI gives 504 Gateway Time-out
When trying to run it manually then I'm getting the following error.
sudo /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml
What's wrong with it?
  • You need local C and run as repetierserver user:
    sudo -u repetierserver LC_ALL=C /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml
    is the manual way to start it in console.
  • edited July 2021
    Thank you.
    Now it looks like it's waiting for "Reading firmware data ..."
    pi@Repetier-Server:~ $ sudo -u repetierserver LC_ALL=C /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml
    Read configuration file /usr/local/Repetier-Server/etc/RepetierServer.xml
    Testing alternative config: "/usr/local/Repetier-Server/etc/RepetierServer-extra.xml"
    Testing alternative config: "/var/lib/Repetier-Server/database/RepetierServer.xml"
    ServerSetting::init()
    Reading server settings...
    18:43:38.475: Imported external command Shutdown Server
    18:43:38.475: Imported external command Reboot Server
    18:43:38.475: Imported external command Restart Klipper
    18:43:38.475: Imported external command Power Printer Off
    18:43:38.475: Imported external command Power Printer On
    18:43:38.475: Imported allowed execute command poweron
    18:43:38.476: Imported allowed execute command poweroff
    18:43:38.476: Webdirectory: /usr/local/Repetier-Server/www/
    18:43:38.476: Storage directory: /var/lib/Repetier-Server/
    18:43:38.476: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
    18:43:38.476: Directory for temporary files: /tmp/
    18:43:38.476: Reading firmware data ...
    Edit: After ~10min it's still waiting at the same spot.
  • I'm still not able to get 1.1.0 running.
    When I downgraded the repetier-server from 1.1.0 to 1.0.4 then version 1.0.4 immediately started to work.
    Tried to install the latest version once more but it stopped at the same point.
    When manually running then it stops on "Reading firmware data ..." and nothing more.
    It's stuck at that point.
  • Ok, that is strange since i can read all firmware definitions. Do you have any own firmware definition files or modified versions? After that output and next one it also loads database/webcalls.json
    To see which file it is handling where the hang happens you could start it with strace like this:
    sudo -u repetierserver LC_ALL=C strace /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml
    Especially the last output with
    open("
    would be of interest, so we know which file causes the hang. You can then send me that file for analysis. It is either defect or has mods from your side causing it I guess, but it should not hang in any case, so interested to see how it can hang.
  • Hi,
    Sent that file to info email.
    Yes, I have my own lines in firmware file Klipper.xml but this file
    is always overwritten during install.
  • I used a new SD card and installed a fresh Raspberry Pi image V26.
    After restoring from backup and configuring everything, it now looks okay.
  • Hello,
    I have exactly the same problem. Switched from 1.03 to 1.1 and my server no longer responds: 504 Gateway Time-out
    I have my license since 2019 and I have not had any problem.
    Florian
  • edited August 2021
    Hello Florian,
    We already noticed and fixed this 504 issue in version 1.1.2, which is also available now.
    To get your current system working again, please reboot your server. After that you can install the fixed update.
    I have again the same issue.
    Updated to the latest from 1.1.1 (like instructed in changelog)
    My 1.1.1 was a clean install from the image.
    The RepetierServer service is not starting correctly it runs till "Reading firmware data ..." and stays there.
    pi@RepetierServer:~ $ sudo -u repetierserver LC_ALL=C /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml      Read configuration file /usr/local/Repetier-Server/etc/RepetierServer.xml
    16:27:12.549: Imported external command Shutdown Server
    16:27:12.550: Imported external command Reboot Server
    16:27:12.551: Imported external command Restart Klipper
    16:27:12.551: Imported external command Power Printer Off
    16:27:12.552: Imported external command Power Printer On
    16:27:12.552: Imported allowed execute command poweron
    16:27:12.553: Imported allowed execute command poweroff
    16:27:12.553: Webdirectory: /usr/local/Repetier-Server/www/
    16:27:12.554: Storage directory: /var/lib/Repetier-Server/
    16:27:12.554: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
    16:27:12.554: Directory for temporary files: /tmp/
    16:27:12.556: Reading firmware data ...
    The strace is more or less the same as the previous time
    rk(0x1e36000)                          = 0x1e36000
    open("/dev/urandom", O_RDONLY|O_LARGEFILE) = 8
    read(8, "O\210\220\3324\254\224\261Q\\\1w/ -f\225S\0206\367\311t\f,\201\206#6\251\224\344"..., 252) = 252
    close(8)                                = 0
    stat64("/usr/local/Repetier-Server/firmware/MK4duo.xml", {st_mode=S_IFREG|0644, st_size=18410, ...}) = 0
    open("/usr/local/Repetier-Server/firmware/MK4duo.xml", O_RDONLY|O_LARGEFILE) = 8
    read(8, "<?xml version=\"1.0\" encoding=\"UT"..., 4092) = 4092
    read(8, "erTemperatureWait\">M191 S{i:temp"..., 4092) = 4092
    open("/dev/urandom", O_RDONLY|O_LARGEFILE) = 9
    read(9, "\222\r\341\23\225h;\5\356A\22\23l\360\360B\275\223\177\356jZ\20\21\255\223\305\31\244ZJ\346"..., 252) = 252
    close(9)                                = 0
    read(8, "\"sdMounted\" value=\"0\">^SD card r"..., 4092) = 4092
    read(8, "cceleration\">M201 .*X(\\d+\\.?\\d*)"..., 4092) = 4092
    read(8, "\\d+) Baudrate</setting>\n        "..., 4092) = 2042
    read(8, "", 4092)                       = 0
    close(8)                                = 0
    brk(0x1e37000)                          = 0x1e37000
    brk(0x1e38000)                          = 0x1e38000
    brk(0x1e39000)                          = 0x1e39000
    brk(0x1e3a000)                          = 0x1e3a000
    brk(0x1e3b000)                          = 0x1e3b000
    brk(0x1e3c000)                          = 0x1e3c000
    brk(0x1e3d000)                          = 0x1e3d000
    brk(0x1e3e000)                          = 0x1e3e000
    Now installing back the previous version 1.1.1 is also not working.
    There's something after version 1.0.4 (That version was working)
    Tried these packages:
    http://download.repetier.com/files/server/debian-armhf/Repetier-Server-1.1.2-Linux.deb
    http://download.repetier.com/files/server/debian-armhf/Repetier-Server-1.1.1-Linux.deb
    The next after "Reading firmware data ..." is the network?
    Maybe there is something that this step cannot be initiated.
    I'm not very interested to make again a clean install from the image.
    I think I found a cause and solution to my issue.
    I made previously a backup folder under /usr/local/Repetier-Server/firmware/
    where I stored the Klipper.xml firmware file previous version before trying 1.1.2 update.
    I also had this folder before my a fresh install from the image.
    It looks that this folder and content somehow messed up with the RepetierServer server.
    After deleting that folder from the firmware folder everything started to work.
    Till version 1.0.4 that folder didn't have any effect.
  • Code is this:
            RLog::log("Reading firmware data ...");
            Firmware::readFirmwares();
            WebCall::load();
            RLog::log("Starting Network ...");
    So if we assume it is after reading firmware data it is your database/webcalls.json file. Can you post your file so I can test if it works for me and if not why it is hanging.
    Thanks for the info.
    I think the bad boy was my extra backup folder & content inside the firmware directory.
    At least after removing that extra folder the service started to work.
    I don't have such file on /var/lib/Repetier-Server/database folder.
    drwxr-x---  2 repetierserver dialout  4096 Aug  7 17:53 .
    drwxr-xr-x 15 repetierserver dialout  4096 Jul 28 22:13 ..
    -rw-r-----  1 repetierserver dialout  3959 Jul 29 00:47 extcommands.xml
    -rw-r-----  1 repetierserver dialout     3 Jul 29 00:44 gpio.json
    -rw-r-----  1 repetierserver dialout 66560 Aug  5 00:49 history.sql
    -rw-r-----  1 repetierserver dialout  2048 Aug  6 22:10 key.sql
    -rw-r-----  1 repetierserver dialout  1211 Jul 28 22:13 renderer.json
    -rw-r-----  1 repetierserver dialout   323 Jul 28 22:13 repetier-network-stored.xml
    -rw-r-----  1 repetierserver dialout   323 Jul 28 22:13 repetier-network.xml
    -rw-r-----  1 repetierserver dialout 37888 Aug  6 22:10 settings.sql
    -rw-r-----  1 repetierserver dialout  5120 Aug  4 22:15 user.sql
    -rw-r-----  1 repetierserver dialout 23552 Aug  4 22:16 workdispatcher.sql
    At the moment I have 1.1.2 version up & running.
    Thank you for your support.
  • You really found it. Tried it and with extra folder it also failed to start. Actually any file not ending with .xml would have caused this. Have fixed this for next update. Thanks.
