repetier 2.0 custom machine(not a printer)
Good day, I am using repeater 2.0 on ruramps 1.3 due, making a custom machine and faced such a problem when starting my machine, it turns out that commands are received but not processed
  • The machine processes the first 10-20 lines of g code but then stops executing them
  • tried to run via repetier host and reprap discount smart controller the result is the same
  • Can you provide a full log example of this. Either you are not communicating or commands are ignored due to some error state. Normally it is visible especially if you start after a reset so firmware initialization is also catched in log.
  • 09:40:06.501 : N14 G92 A0*118
    09:40:06.506 : N15 G0 A13*126
    09:40:06.514 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:0.000
    09:40:06.514 : N16 G28 A0*117
    09:40:08.095 : X:0.00 Y:0.00 Z:0.000 E:0.0000 A:13.00 B:0.00
    09:40:08.640 : Warning:Endstop for axis A did not untrigger for retest!
    09:40:08.669 : X:0.00 Y:0.00 Z:0.000 E:0.0000 A:0.00 B:0.00
    09:40:08.672 : X:0.00 Y:0.00 Z:0.000 E:0.0000 A:0.00 B:0.00
    09:40:10.319 : N17 M530 S1 L0*13
    09:40:10.323 : N18 M531 last*55
    09:40:10.328 : N19 M104 T0 S240*31
    09:40:10.331 : N20 G28 Z0*107
    09:40:10.336 : N21 G28 Y0*105
    09:40:10.340 : X:0.00 Y:0.00 Z:0.000 E:0.0000 A:0.00 B:0.00
    09:40:11.712 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:11.916 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:11.916 : N22 M532 X8.33333 L0*22
    09:40:11.920 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:13.329 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:13.334 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:13.334 : N23 G28 A0*115
    09:40:13.338 : N24 G0 Z15 F1000*6
    09:40:13.342 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:16.467 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:16.471 : X:0.00 Y:0.00 Z:-5.000 E:0.0000 A:0.00 B:0.00
    09:40:16.471 : N25 M532 X13.88889 L0*33
    09:40:16.475 : N26 G0 Y18 F500*62
    09:40:16.479 : N27 G92 E0 B0*32
    09:40:16.484 : N28 G0 B740 E2 F100000*114
    09:40:16.491 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:0.000
    09:40:16.492 : N29 G92 E0*124
    09:40:16.496 : N30 G0 E-3*97
    09:40:16.504 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:0.000
    09:40:16.504 : N31 G0 Z0 F3000*52
    09:40:18.553 : N32 M532 X30.55556 L0*41
    09:40:18.557 : N33 G0 Y0 F1000 A13*84
    09:40:18.561 : N34 G28 A0*117
    09:40:18.564 : N35 G92 E0*113
    09:40:23.795 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:13.00 B:740.00
    09:40:24.299 : Warning:Endstop for axis A did not untrigger for retest!
    09:40:24.327 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:740.00
    09:40:24.332 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:740.00
    09:40:24.340 : N36 M532 X38.88889 L0*42
    09:40:24.348 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:0.000
    09:40:24.350 : N37 G0 Z16 F3000*5
    09:40:24.356 : N38 G0 Y0 F3000*62
    09:40:24.359 : N39 M532 X44.44444 L0*35
    09:40:24.364 : N40 G92 E0 B0*33
    09:40:24.369 : N41 G0 E3*74
    09:40:24.377 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-740.000
    09:40:24.377 : N42 G92 E0 B0*35
    09:40:24.381 : N43 G0 B800 E0.5 F100000*109
    09:40:24.389 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-740.000
    09:40:24.390 : N44 G92 E0 B0*37
    09:40:24.393 : N45 G0 E-0.5  B180 F100000*103
    09:40:24.401 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-1540.000
    09:40:24.401 : N46 G0 Y0 Z13 F1000*77
    09:40:25.614 : N47 M532 X63.88889 L0*34
    09:40:25.618 : N48 G0 Z0 F1000*56
    09:40:25.622 : N49 G0 Y17.5 F900 A13*76
    09:40:25.626 : N50 G28 A0*119
    09:40:25.630 : N51 G0 Z16 F3000*5
    09:40:31.877 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:13.00 B:1720.00
    09:40:32.348 : Warning:Endstop for axis A did not untrigger for retest!
    09:40:32.376 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:1720.00
    09:40:32.381 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:1720.00
    09:40:32.389 : N52 M532 X75 L0*54
    09:40:32.393 : N53 G92 E0 B0*35
    09:40:32.398 : N54 G0 E0.5*86
    09:40:32.405 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-1720.000
    09:40:32.405 : N55 G0 Y17*102
    09:40:32.409 : N56 G92 E0 B0*38
    09:40:32.413 : N57 G0 B740 E3.5 F100000*96
    09:40:32.421 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-1720.000
    09:40:32.421 : N58 G92 E0 B0*40
    09:40:32.426 : N59 G0 E-3  B740  F100000*88
    09:40:32.434 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-2460.000
    09:40:32.434 : N60 G0 Y16 Z12 F3000*125
    09:40:33.613 : N61 M532 X97.22222 L0*38
    09:40:33.617 : Задача завершена в 08.07.2021 9:40
    09:40:33.617 : Время печати:23 с
    09:40:33.617 : Отправлено строк:36
    09:40:33.622 : N62 G0 Z0 F1000*48
    09:40:33.625 : N63 M530 S0*83
    09:41:17.400 : N64 M530 S1 L0*9
    09:41:17.403 : N65 M531 last*61
    09:41:17.409 : N66 M104 T0 S240*23
    09:41:17.413 : N67 G28 Z0*104
    09:41:17.417 : N68 G28 Y0*100
    09:41:17.420 : X:0.00 Y:16.00 Z:0.000 E:-3.0000 A:0.00 B:3200.00
    09:41:19.522 : X:0.00 Y:16.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:19.727 : X:0.00 Y:16.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:19.727 : N69 M532 X0.38168 L0*22
    09:41:19.731 : X:0.00 Y:16.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:22.742 : X:0.00 Y:0.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:22.745 : X:0.00 Y:0.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:22.745 : N70 G28 A0*117
    09:41:22.750 : N71 G0 Z15 F1000*6
    09:41:22.754 : X:0.00 Y:0.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:25.904 : X:0.00 Y:0.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:25.908 : X:0.00 Y:0.00 Z:-5.000 E:-3.0000 A:0.00 B:3200.00
    09:41:25.908 : N72 M532 X0.63613 L0*25
    09:41:25.913 : N73 G0 Y18 F500*62
    09:41:25.915 : N74 G92 E0 B0*38
    09:41:25.920 : N75 G0 B740 E2 F100000*122
    09:41:25.928 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-3200.000
    09:41:25.928 : N76 G92 E0*118
    09:41:25.932 : N77 G0 E-3*98
    09:41:25.940 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-3200.000
    09:41:25.941 : N78 G0 Z0 F3000*57
    09:41:27.988 : N79 M532 X1.39949 L0*28
    09:41:27.992 : N80 G0 Y0 F1000 A13*92
    09:41:27.997 : N81 G28 A0*123
    09:41:28.000 : N82 G92 E0*125
    09:41:33.231 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:13.00 B:3940.00
    09:41:33.605 : Warning:Endstop for axis A did not untrigger for retest!
    09:41:33.637 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:3940.00
    09:41:33.641 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:3940.00
    09:41:33.649 : N83 M532 X1.78117 L0*31
    09:41:33.654 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-3200.000
    09:41:33.658 : N84 G0 Z16 F3000*13
    09:41:33.661 : N85 G0 Y0 F3000*56
    09:41:33.665 : N86 G92 E0 B0*43
    09:41:33.670 : N87 G0 E3*64
    09:41:33.678 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-3940.000
    09:41:33.678 : N88 M532 X2.29008 L0*28
    09:41:33.682 : N89 G92 E0 B0*36
    09:41:33.686 : N90 G0 B800 E0.5 F100000*99
    09:41:33.693 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-3940.000
    09:41:33.695 : N91 G92 E0 B0*45
    09:41:33.703 : N92 G0 E-0.5  B180 F100000*109
    09:41:33.707 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-4740.000
    09:41:33.711 : N93 G0 Y0 Z13 F1000*69
    09:41:34.918 : N94 M532 X2.92621 L0*28
    09:41:34.923 : N95 G0 Z0 F1000*56
    09:41:34.927 : N96 G0 Y17.5 F900 A13*78
    09:41:34.931 : N97 G28 A0*124
    09:41:34.936 : N98 G0 Z16 F3000*0
    09:41:41.182 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:13.00 B:4920.00
    09:41:41.771 : Warning:Endstop for axis A did not untrigger for retest!
    09:41:41.800 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:4920.00
    09:41:41.805 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:4920.00
    09:41:41.805 : N99 M532 X3.43512 L0*31
    09:41:41.816 : N100 G92 E0 B0*20
    09:41:41.820 : N101 G0 E0.5*103
    09:41:41.829 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-4920.000
    09:41:41.829 : N102 G0 Y17*85
    09:41:41.833 : N103 G92 E0 B0*23
    09:41:41.837 : N104 G0 B740 E3.5 F100000*87
    09:41:41.845 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-4920.000
    09:41:41.845 : N105 G92 E0 B0*17
    09:41:41.849 : N106 G0 E-3  B740  F100000*99
    09:41:41.858 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-5660.000
    09:41:41.858 : N107 G0 Y16 Z12 F3000*77
    09:41:43.025 : N108 M532 X4.45293 L0*41
    09:41:43.029 : N109 G0 Z0 F1000*12
    09:41:43.033 : N110 G0 Y0 F1000 A13*100
    09:41:43.037 : N111 G28 A0*67
    09:41:43.042 : N112 G92 E0*69
    09:41:51.013 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:13.00 B:6400.00
    09:41:51.499 : Warning:Endstop for axis A did not untrigger for retest!
    09:41:51.529 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:6400.00
    09:41:51.533 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:6400.00
    09:41:51.541 : N113 M532 X4.96183 L0*47
    09:41:51.549 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-5660.000
    09:41:51.549 : N114 G0 Z16 F3000*53
    09:41:51.553 : N115 G0 Y0 F3000*0
    09:41:51.557 : N116 G92 E0 B0*19
    09:41:51.561 : N117 G0 E3*120
    09:41:51.569 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-6400.000
    09:41:51.570 : N118 G92 E0 B0*29
    09:41:51.574 : N119 G0 B800 E0.5 F100000*83
    09:41:51.582 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-6400.000
    09:41:51.582 : N120 G92 E0 B0*22
    09:41:51.586 : N121 G0 E-0.5  B180 F100000*84
    09:41:51.594 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-7200.000
    09:41:51.594 : N122 G0 Y0 Z13 F1000*126
    09:41:52.811 : N123 M532 X6.10687 L0*35
    09:41:52.814 : N124 G0 Z0 F1000*3
    09:41:52.819 : N125 G0 Y17.5 F900 A13*119
    09:41:52.823 : N126 G28 A0*71
    09:41:52.827 : N127 G0 Z16 F3000*53
    09:41:59.073 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:13.00 B:7380.00
    09:41:59.557 : Warning:Endstop for axis A did not untrigger for retest!
    09:41:59.586 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:7380.00
    09:41:59.590 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:7380.00
    09:41:59.597 : N128 M532 X6.61578 L0*45
    09:41:59.601 : N129 G92 E0 B0*31
    09:41:59.605 : N130 G0 E0.5*101
    09:41:59.614 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-7380.000
    09:41:59.616 : N131 G0 Y17*85
    09:41:59.622 : N132 G92 E0 B0*21
    09:41:59.626 : N133 M532 X7.12468 L0*34
    09:41:59.635 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-7380.000
    09:41:59.635 : N134 G0 B740 E3.5 F100000*84
    09:41:59.642 : N135 G92 E0 B0*18
    09:41:59.647 : N136 G0 E-3  B740  F100000*96
    09:41:59.655 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-8120.000
    09:41:59.655 : N137 G0 Y16 Z12 F3000*78
    09:41:59.659 : N138 G0 Z0 F1000*14
    09:41:59.663 : N139 G0 Y0 F1000 A13*111
    09:41:59.667 : N140 G28 A0*71
    09:41:59.671 : N141 G92 E0*67
    09:42:01.674 : buy:processing
    09:42:08.531 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:13.00 B:8860.00
    09:42:09.015 : Warning:Endstop for axis A did not untrigger for retest!
    09:42:09.043 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:8860.00
    09:42:09.047 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:8860.00
    09:42:09.056 : N142 M532 X8.14249 L0*40
    09:42:09.060 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-8120.000
    09:42:09.063 : N143 G0 Z16 F3000*55
    09:42:09.068 : N144 G0 Y0 F3000*4
    09:42:09.072 : N145 G92 E0 B0*21
    09:42:09.076 : N146 G0 E3*124
    09:42:09.084 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-8860.000
    09:42:09.085 : N147 G92 E0 B0*23
    09:42:09.088 : N148 G0 B800 E0.5 F100000*87
    09:42:09.097 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-8860.000
    09:42:09.100 : N149 M532 X8.90585 L0*40
    09:42:09.104 : N150 G92 E0 B0*17
    09:42:09.109 : N151 G0 E-0.5  B180 F100000*83
    09:42:09.117 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-9660.000
    09:42:09.118 : N152 G0 Y0 Z13 F1000*121
    09:42:09.125 : N153 G0 Z0 F1000*3
    09:42:09.129 : N154 G0 Y17.5 F900 A13*113
    09:42:09.133 : N155 G28 A0*67
    09:42:09.137 : N156 G0 Z16 F3000*51
    09:42:16.309 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:13.00 B:9840.00
    09:42:16.772 : Warning:Endstop for axis A did not untrigger for retest!
    09:42:16.801 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:9840.00
    09:42:16.805 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:9840.00
    09:42:16.805 : N157 M532 X9.79644 L0*47
    09:42:16.809 : N158 G92 E0 B0*25
    09:42:16.830 : N159 G0 E0.5*106
    09:42:16.834 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-9840.000
    09:42:16.838 : N160 G0 Y17*81
    09:42:16.842 : N161 G92 E0 B0*19
    09:42:16.846 : N162 G0 B740 E3.5 F100000*87
    09:42:16.854 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-9840.000
    09:42:16.854 : N163 G92 E0 B0*17
    09:42:16.858 : N164 G0 E-3  B740  F100000*103
    09:42:16.867 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-10580.000
    09:42:16.867 : N165 M532 X10.68702 L0*21
    09:42:16.871 : N166 G0 Y16 Z12 F3000*74
    09:42:16.875 : N167 G0 Z0 F1000*4
    09:42:16.879 : N168 G0 Y0 F1000 A13*107
    09:42:16.883 : N169 G28 A0*76
    09:42:16.888 : N170 G92 E0*65
    09:42:25.730 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:13.00 B:11320.00
    09:42:26.234 : Warning:Endstop for axis A did not untrigger for retest!
    09:42:26.267 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:11320.00
    09:42:26.271 : X:0.00 Y:0.00 Z:0.000 E:-3.0000 A:0.00 B:11320.00
    09:42:26.279 : N171 M532 X11.32316 L0*31
    09:42:26.284 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-10580.000
    09:42:26.287 : N172 G0 Z16 F3000*53
    09:42:26.291 : N173 G0 Y0 F3000*0
    09:42:26.296 : N174 G92 E0 B0*23
    09:42:26.299 : N175 G0 E3*124
    09:42:26.308 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-11320.000
    09:42:26.308 : N176 G92 E0 B0*21
    09:42:26.313 : N177 G0 B800 E0.5 F100000*91
    09:42:26.321 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-11320.000
    09:42:26.322 : N178 G92 E0 B0*27
    09:42:26.329 : N179 G0 E-0.5  B180 F100000*89
    09:42:26.333 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-12120.000
    09:42:26.333 : N180 G0 Y0 Z13 F1000*118
    09:42:26.336 : N181 G0 Z0 F1000*12
    09:42:26.341 : N182 G0 Y17.5 F900 A13*122
    09:42:26.345 : N183 G28 A0*72
    09:42:26.349 : N184 G0 Z16 F3000*60
    09:42:33.533 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:13.00 B:12300.00
    09:42:33.948 : Warning:Endstop for axis A did not untrigger for retest!
    09:42:33.980 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:12300.00
    09:42:33.984 : X:0.00 Y:17.50 Z:0.000 E:-0.5000 A:0.00 B:12300.00
    09:42:33.992 : N185 M532 X12.9771 L0*42
    09:42:33.997 : N186 G92 E0 B0*26
    09:42:34.001 : N187 G0 E0.5*105
    09:42:34.009 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-12300.000
    09:42:34.009 : N188 G0 Y17*87
    09:42:34.013 : N189 G92 E0 B0*21
    09:42:34.017 : N190 M532 X13.486 L0*29
    09:42:34.025 : X_OFFSET:0.000 Y_OFFSET:0.000 Z_OFFSET:0.000 A_OFFSET:0.00000 B_OFFSET:-12300.000
    09:42:34.025 : N191 G0 B740 E3.5 F100000*91
    09:42:34.029 : N192 G92 E0 B0*31
  • Log is incomplete - it does not show firmware answers like "ok" and "wait". Also please comment where the commands did not get executed any more - I can not know that.
    With safe homing and if required homed axis "Warning:Endstop for axis A did not untrigger for retest!" might cause moves to be ignored.
