Cannot see projects/objects from another server
I have created a project in my RPI1 but I cannot see it in RPI2, and viceversa.
Both servers are correctly configured to share projects, the API keys are correctly entered in "alternative servers", their status is in fact in green, so theoretically they see each other.
I've also tried changing the API keys of both servers and then reassigning them as alternatives, but it still doesn't work.
What if both of my servers have items to share? Do I have to enable it in both?
Having two identical printers each with its RPI it would be very useful to be able to share gcodes between both, without going through the "objects" section.
But there is as well an option to share projects that must be enabled. If the pc is shown in green it‘s contens shoukd then appear in projects by selecting that server in the server dropdown.
Yet it does not happen here, inexplicable.
Both servers see each other in green.
In the drop down menu I always see the other server name, but zero projects.
Without a debugged log it is difficult to understand why.
Is this the same in your case? When you connect directly to the remote server do you see the projects there?
