Print fails after some time with "Error code: STATUS_BREAKPOINT" then "500 Internal Server Error"
My prints keep failing after different amounts of time. The web view of Repetier-Server gave me this message "Error code: STATUS_BREAKPOINT". Then when I try to reload the page it says "500 Internal Server Error" and "nginx/1.14.2". I have to reboot the Raspberry Pi before I can do anything. Any ideas?
I am running this on a Raspberry Pi 3B. I have disconnected my other printers and still get this error. I'm printing on my custom built machine: 350x395x460 BIGTREETECH GTR v1.0 board, using USB.
https://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/
to reduce dependence on printer power and reduce consumption on pi side a bit.
Notes:
When I was only running the single printer that has a jumper on it's motherboard set to not use USB power, I was still getting the errors. Even with the webcam disconnected I was still getting the errors. I may try the 5V power isolation later.
The Pi 4 has been running with no problems. I believe the issue was the power on the Pi 3B+. Also, I'm now sure the older printer was causing a USB power issue as well. When plugged in, it would not allow the Pi 4 to boot up. Once I disabled the USB power pin for the older printer, the Pi 4 boots fine. My problem may have been both the power supply for the Pi 3B+ and the older printer USB power pin combined.
I believe the problem has been diagnosed as a power issue and has been solved.
ThanX
