Height map - First and last meadure always give false reading
Hello,
Not sure if it was a firmware related or application related.
I use the latest repetier firmware (0.9.24) and when I use the Height Map tool, always the first and last measure gives me false results.
Here is an example:
Here is an example:
X: -50.00 -33.33 -16.67 0.00 16.67 33.33 50.00
y:50.00 4.68 4.74 4.68 4.66 4.71 4.79 3.85
y:35.00 4.65 4.55 4.46 4.46 4.50 4.59 4.68
y:20.00 4.48 4.38 4.32 4.29 4.31 4.38 4.51
y:5.00 4.36 4.28 4.21 4.19 4.18 4.25 4.38
y:-10.00 4.31 4.25 4.15 4.10 4.11 4.18 4.29
y:-25.00 4.30 4.24 4.16 4.10 4.11 4.16 4.29
y:-40.00 2.79 4.29 4.21 4.15 4.18 4.24 4.35
and now I changed the area to -20 to 20 both X and Y:
X: -20.00 -13.33 -6.67 0.00 6.67 13.33 20.00
y:20.00 4.32 4.31 4.31 4.29 4.29 4.30 4.32
y:13.33 4.23 4.21 4.20 4.20 4.19 4.18 4.21
y:6.67 4.19 4.18 4.18 4.15 4.15 4.16 4.16
y:0.00 4.18 4.15 4.13 4.13 4.11 4.15 4.14
y:-6.67 4.16 4.14 4.11 4.11 4.11 4.10 4.13
y:-13.33 2.85 4.15 4.14 4.11 4.10 4.11 4.15
y:-20.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Frist - the last row is all 0.00 and in the log is does have values:
18:07:12.178 : Z-probe:2.84 X:-19.53 Y:-13.41 zCorr:0.00
18:07:12.594 : Z-probe:4.13 X:-12.85 Y:-13.42 zCorr:0.00
18:07:13.090 : Z-probe:4.13 X:-6.19 Y:-13.42 zCorr:0.00
18:07:13.570 : Z-probe:4.10 X:0.47 Y:-13.42 zCorr:0.00
18:07:14.050 : Z-probe:4.09 X:7.15 Y:-13.42 zCorr:0.00
18:07:14.529 : Z-probe:4.10 X:13.81 Y:-13.42 zCorr:0.00
18:07:15.025 : Z-probe:4.14 X:20.47 Y:-13.42 zCorr:0.00
18:07:16.001 : Z-probe:4.15 X:-19.53 Y:-6.76 zCorr:0.00
18:07:16.496 : Z-probe:4.13 X:-12.85 Y:-6.76 zCorr:0.00
18:07:16.977 : Z-probe:4.10 X:-6.19 Y:-6.76 zCorr:0.00
18:07:17.456 : Z-probe:4.10 X:0.47 Y:-6.76 zCorr:0.00
18:07:17.952 : Z-probe:4.10 X:7.15 Y:-6.76 zCorr:0.00
18:07:18.432 : Z-probe:4.10 X:13.81 Y:-6.76 zCorr:0.00
18:07:18.912 : Z-probe:4.13 X:20.47 Y:-6.76 zCorr:0.00
18:07:19.888 : Z-probe:4.16 X:-19.53 Y:-0.10 zCorr:0.00
18:07:20.384 : Z-probe:4.14 X:-12.85 Y:-0.10 zCorr:0.00
18:07:20.864 : Z-probe:4.13 X:-6.19 Y:-0.10 zCorr:0.00
18:07:21.359 : Z-probe:4.11 X:0.47 Y:-0.10 zCorr:0.00
18:07:21.839 : Z-probe:4.11 X:7.15 Y:-0.10 zCorr:0.00
18:07:22.319 : Z-probe:4.14 X:13.81 Y:-0.10 zCorr:0.00
18:07:22.815 : Z-probe:4.14 X:20.47 Y:-0.10 zCorr:0.00
18:07:23.790 : Z-probe:4.19 X:-19.53 Y:6.56 zCorr:0.00
18:07:24.286 : Z-probe:4.18 X:-12.85 Y:6.56 zCorr:0.00
18:07:24.782 : Z-probe:4.18 X:-6.19 Y:6.56 zCorr:0.00
18:07:25.263 : Z-probe:4.15 X:0.47 Y:6.56 zCorr:0.00
18:07:25.758 : Z-probe:4.15 X:7.15 Y:6.56 zCorr:0.00
18:07:26.238 : Z-probe:4.18 X:13.81 Y:6.56 zCorr:0.00
18:07:26.734 : Z-probe:4.16 X:20.47 Y:6.56 zCorr:0.00
18:07:27.709 : Z-probe:4.23 X:-19.53 Y:13.24 zCorr:0.00
18:07:28.205 : Z-probe:4.21 X:-12.85 Y:13.24 zCorr:0.00
18:07:28.701 : Z-probe:4.20 X:-6.19 Y:13.24 zCorr:0.00
18:07:29.213 : Z-probe:4.20 X:0.47 Y:13.24 zCorr:0.00
18:07:29.693 : Z-probe:4.19 X:7.15 Y:13.24 zCorr:0.00
18:07:30.188 : Z-probe:4.19 X:13.81 Y:13.24 zCorr:0.00
18:07:30.685 : Z-probe:4.21 X:20.47 Y:13.24 zCorr:0.00
18:07:31.676 : Z-probe:4.26 X:-19.53 Y:19.90 zCorr:0.00
18:07:32.172 : Z-probe:4.26 X:-12.85 Y:19.90 zCorr:0.00
18:07:32.668 : Z-probe:4.26 X:-6.19 Y:19.90 zCorr:0.00
18:07:33.180 : Z-probe:4.25 X:0.47 Y:19.90 zCorr:0.00
18:07:33.676 : Z-probe:4.25 X:7.15 Y:19.90 zCorr:0.00
18:07:34.171 : Z-probe:4.25 X:13.81 Y:19.90 zCorr:0.00
18:07:34.668 : Z-probe:4.26 X:20.47 Y:19.90 zCorr:0.00
18:07:35.659 : Z-probe:4.32 X:-19.53 Y:26.57 zCorr:0.00
18:07:36.171 : Z-probe:4.31 X:-12.85 Y:26.57 zCorr:0.00
18:07:36.682 : Z-probe:4.31 X:-6.19 Y:26.57 zCorr:0.00
18:07:37.178 : Z-probe:4.30 X:0.47 Y:26.57 zCorr:0.00
18:07:37.691 : Z-probe:4.30 X:7.15 Y:26.57 zCorr:0.00
18:07:38.186 : Z-probe:4.30 X:13.81 Y:26.57 zCorr:0.00
18:07:38.705 : Z-probe:4.32 X:20.47 Y:26.57 zCorr:0.00
And second - this "2.84" comes from nowhere again.. it's not possible that in the first test if was in the right-bottom corner,
and in the second test it was there again, because this position in the first test gave something around 4 like it should..
Thanks for you help
Thanks for you help
I can't find the logic here, because with -20 to 20 grid I don't get the last row, but with -55 to 55 or even -60 to 60 grid,
Also, why is the first measurement is always giving me wrong reading?
The first measure is again different than the others, but also the second one.
I tried to print this file but I failed because somewhere around x-50 y35 (not sure)
Another thing,
When I tried not the Height Map, but first sent the home to the first location manually, the first measure was good.
