Using a Thermocouple with Repetier
Dear Community
I want to use a Thermocouple instead of a thermistor for my hotend.
I´m using a RADDS v1.2 board with an Arduino Due.
In the configurator, I can already choose a thermocouple amplifier:
This breakout board generates a voltage of 0 - 3,3 V for -250°C to 410 °C.
My first question is the resolution: Does the Repetier firmware read the analog voltage with 10 bits resolution (resulting in 0,64°C steps) or with 12 bit resolution (the DUE has 12 bit ADCs, older boards have 10bit ADCs).
Second question: Can I wire the voltage output of the breakout board to the thermistor pins or do I have to use the spare analog inputs of the RADDS?
When I have a look at the diagram that´s shown in the configuration tool, the thermistor input is directly wired to the analog input an GND, but can the voltage be pulled up by Vref?
The alternativ would be to use the analog input on the RADDS
But which Pin is it in the firmware?
Or can I wire the Thermocouple to the RADDS without any additional electronics?
