Repetier Server (only!) severe underextrusion since BMG upgrade
Hello there,
I'm currently stuck with a problem that I just can't get my head around.
I've been using Repetier Server Pro with my Prusa MK3S+ for a few weeks now without any problems. But since upgrading my extruder to a Bondtech BMG and changing the extruder e-steps accordingly, I can not get any prints with correct extrusion for the life of me. But whenever I print the same file(!) with pronterface or via sd card, everything looks fine. It must have something to do with repetier server.
I have not made any changes to it, I didn't add any custom gcode to repetier server, and the problem is only with the Bondtech BMG extruder. I have no problems with my other Prusa's on the same repetier server installation. I have also tried to delete and re-add the printer, and even tried a new USB cable.
I did recalibrate my extruder step value via pronterface after the upgrade and I can see the correct value in the console output. I don't have any idea where I could start with troubleshooting, other than asking here.
My problem sounds a lot like this one: https://forum.repetier.com/discussion/6410/wanhao-d6-plus-repetierserver-cura#latest
But the e-steps of the e axis are correct, it was at 415 initially, 430 now after calibration.
Any help is much appreciated, thank you.
Kind regards.
Kind regards.
Just to be sure - does your gcode contain a command that sets relative or absolute extrusion explicitly? Assuming relative and being in absolute gives nearly no extrusion at all.
If you are on 1.0.4 beta please upgrade - there was a short time a bug in it skipping some command like setting extrusion relative with bad luck so that might also be a reason.
These are all possible reasons I currently can think of. For testing you can go to console also and check commands being send to see what happens and try manual extrusion as a test.
I am using 1.0.3 on Mac. It runs on a Mac Mini Server.
The flow multiplier is per default on 95%. I think PrusaSlicer does this automatically. It's been on 95% ever since, even before the problem started.
You can give me a download link for the print and I try. Have also a prusa so should be easy to see if it works for me with same code. At least if you do not set steps per mm in gcode. I know that prusa slicer at least sets the accelerations there.
Here is a screengrab of my settings:
http://dev.wildfang.media/misc/screenshot.png
I uploaded the gcode to my server, I'm really grateful you take the time to look at it. Thank you!
http://dev.wildfang.media/misc/3DBenchy_0.15mm_PETG_MK3S_2h2m.gcode
This makes completely no sense. I mean it worked you change hardware and nothing is server and now it does not work. It only makes sense if you have some event gcode that overrides the settings and was optimized for the old extruder. When you activate logging and start a print (after veriyfiying eeprom is correct) the command is at the top, but watch your the first commands might be missing and in the connected.log if activated.
Easier solution might be to download your config as xml file and search for M92.
I agree that it makes no sense, but this is how it actually is. I just can't understand why.
Please see the following examples:
This one - Voron Test Cube - started with Repetier Server, I stopped it in layer 3 as the underextrusion is just severe:
http://dev.wildfang.media/misc/IMG_20210317_105118.jpg
http://dev.wildfang.media/misc/IMG_20210317_105410.jpg
This is the same file, on the same printer, with the same filament, printed just right after stopping the first one, but sent via OctoPrint (shows first layer):
http://dev.wildfang.media/misc/IMG_20210317_105240.jpg
There is absolutely nothing I changed in between, no nozzle cleaning or swapping, no nothing. Printed right after each other, just using different software.
This is my configuration:
http://dev.wildfang.media/misc/Prusa_i3_MKS3.xml
I'm pretty sure that I haven't made any changes in regards to anything...
I'm now going to take a look at any logs I find.
On the other side the images look like the under extrusion has a factor matching 430/280. When you set flow multiplier to 153% would it then look correct? Best adjust it in gcode where it gets set to 95%
I also saw
hope newer firmwares detect the difference.
What does M900 K do?
Sounds like a good lead.
Edit: It still looks kinda weird... A new idea: Could the actual problem be related to temperature, not flow? Or both? Because the PETG is really messy and sticky, it doesn't flow nicely. The temperature is set to 245°, this should be pretty liquid, not sticky at all. So maybe there is a problem with a combination of both? Just an idea.
Stopped the test print at 40%:
http://dev.wildfang.media/misc/IMG_20210317_123456.jpg
http://dev.wildfang.media/misc/IMG_20210317_123507.jpg
http://dev.wildfang.media/misc/IMG_20210317_123523.jpg
http://dev.wildfang.media/misc/IMG_20210317_123543.jpg
I can't quite put the finger on the problem. The amount of filament looks almost right at 150% flow, but still the perimeters are very irregular and not tidy. Also, retraction is off.
The console did not spit out any error. What should I look out for?
The fact that it is so irregular lets make me think you have more an extrusion problem. When you increase flow you extrude always the same factor more, so it should look regular. If extrusion starts to slip due to increased backforce in nozzle you get less extrusion. Reason might be wrong temperature or bad spring pressure or motor current is too low so you loose steps. I saw you are explicitly setting extruder motor current here:
M907 E430 ; set extruder motor current
and 430 mA or what ever unit it may be is not really much. Mit I'm not sur eit is mA at all - Marlin Doxs say to use M906 for TMC with mA. Looking in my slicer results I do not have that line so guess I have more. Unfortunately I can not see what values are set by default.
Initially, I also thought it is a hardware problem. I dismantled the extruder countless times, always with the same result, because as always, I would send the files with Repetier Server. Only when I was using Pronterface for debugging and had perfect print results, I became suspicious, testing different solutions and realizing that the problem only occurs with Repetier Server. I have already spent 4 days trouble shooting then 8-/
So, the printer is connected to my Mac Mini Server via USB. If I send a file from OctoPrint, it prints it perfectly fine. If I send the SAME file from Repetier Server, I get this weird problems with extrusion.
It's the same file, the same printer, the same filament, the same computer. Just sending it with a different software.
If the problem is caused by a mechanical problem like the extruder itself, it would have to appear in every software. Also, printing the file from SD card works fine.
I don't think I'm losing steps, the extruder is not skipping or clicking.
Can there be any hardcoded string for e-steps be hidden in the configuration file? Something that was forgotten to replace with a variable? Something within the definition of the printer? Maybe from testing state? I don't know, some fixed value for the extruder steps on a prusa?
However, I do not understand how this relates - why does it happen, why does the ping pong mode fix it? What does it even do?
I know prusa mini gets in trouble but that is bug on printer side I think.
I just released new 1.0.4 version. So you should update as it fixes some problems I detected. Also nothing that explains the difference.
Maybe it has to do with the Bondtech BMG firmware fork? It states it only changes max z-height and extruder steps, but maybe there is a bug in the communication layer? I don't know. I never had any communication timeouts while printing, and it never froze or anything (that's what my google search came up with for the Ping Pong modus).
I will update, thank you for your time and help!
