failing to compile - extruder z-offset error
I'm trying to upload the latest firmware to my Azteeg X3 pro, downloaded through the 0.92.4 config page.
I'm getting an error about Z_PROBE_Z_OFFSET was not declared with a pointer to line 710 of the eeprom.cpp file.
Any help would really be appreciated. The Repetier firmware has been working quite well, but the z-offset didn't seem to be working quite as expected prompting me to try updating (eg. the step values didn't directly seem to correspond/match the expected height/offset changes).
The Arduino IDE was updated on my machine since I last updated the firmware and I am re-using my configuration.h file from my previous working build (using whatever was current back in early August).
Error message follows:
Arduino: 1.6.5 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Eeprom.cpp: In static member function 'static void EEPROM::initalizeUncached()':
Eeprom.cpp:456: error: 'Z_PROBE_Z_OFFSET' was not declared in this scope
HAL::eprSetFloat(EPR_Z_PROBE_Z_OFFSET,Z_PROBE_Z_OFFSET);
Eeprom.cpp: In static member function 'static void EEPROM::readDataFromEEPROM(bool)':
Eeprom.cpp:711: error: 'Z_PROBE_Z_OFFSET' was not declared in this scope
Exception in thread "AWT-EventQueue-0" java.lang.Error: Error: could not match input
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.zzScanError(CPlusPlusTokenMaker.java:2077)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.yylex(CPlusPlusTokenMaker.java:2311)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.getTokenList(CPlusPlusTokenMaker.java:1901)
at org.fife.ui.rsyntaxtextarea.RSyntaxDocument.getTokenListForLine(RSyntaxDocument.java:416)
at org.fife.ui.rsyntaxtextarea.SyntaxView.paint(SyntaxView.java:719)
at javax.swing.plaf.basic.BasicTextUI$RootView.paint(BasicTextUI.java:1434)
at javax.swing.plaf.basic.BasicTextUI.paintSafely(BasicTextUI.java:737)
at javax.swing.plaf.basic.BasicTextUI.paint(BasicTextUI.java:881)
at javax.swing.plaf.basic.BasicTextUI.update(BasicTextUI.java:860)
at org.fife.ui.rtextarea.RTextAreaBase.paintComponent(RTextAreaBase.java:719)
at org.fife.ui.rsyntaxtextarea.RSyntaxTextArea.paintComponent(RSyntaxTextArea.java:1993)
at javax.swing.JComponent.paint(JComponent.java:1056)
at javax.swing.JComponent.paintChildren(JComponent.java:889)
at javax.swing.JComponent.paint(JComponent.java:1065)
at javax.swing.JViewport.paint(JViewport.java:728)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5219)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1572)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1495)
at javax.swing.RepaintManager.paint(RepaintManager.java:1265)
at javax.swing.JComponent._paintImmediately(JComponent.java:5167)
at javax.swing.JComponent.paintImmediately(JComponent.java:4978)
at javax.swing.RepaintManager$4.run(RepaintManager.java:824)
at javax.swing.RepaintManager$4.run(RepaintManager.java:807)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:807)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:782)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:731)
at javax.swing.RepaintManager.access$1300(RepaintManager.java:64)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1720)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Bed Coating.
