How can I command a single column's motor to move in a Delta printer
Is there a command that will allow me to move only the A or B or C motor a certain distance in a delta printer?
For example, I wish to move column A's motor 32 steps.
Thank you.
Thank you.
or with M17/M18
Moving motor some steps voids stored position and then you need to home to get position back. The only case where this happens is when the end stop offsets are applied after homing.
Maybe I can add it in V2 somehow. Have to think about it. At least I there have a move steps function available.
Sorry for digging out an old post.
I was looking into controlling the motors individually, any chance a feature like this has been implemented already ?
I've got a printer with 3 Z motors and 2 Y motors, i would like to move them individually a few mm before end stop to make sure my X/Y angle and Z/Y angle are always 90 deg during homing.
