Remote access to 3D printer
I am sorry if this question has been asked before...
I have my Prusa 3D-printer connected to a Raspberry Pi running Repetier Server on my local network.
I am using a Netgear Router.
Can someone please provide simple step by step instructions on how I can access my printer controls (and in particular my Pi webcam) remotely (outside my local network)?
Thank you very much!
https://www.repetier-server.com/knowledgebase/access-server-from-internet/
if it is possible in your case you need to port forward port 3344 of the raspberry ip number, then you can connect to the routers ip with the forwarded port. This simple solution only works if you do not share your official ip with others. Then you need one of the other solutions.
