Disable queue
Hello.
Are there any options to disable the possibility to put files in queue?
Thank you.
  • No that is not possible. Actually even the current print gets copied to queue first and then started. And when a print gets automatically aborted it stays in queue to be reprinted since it did not finish. So that is an essential part.
  • Got it. Thank you for the answer.
