Temperature reading doesn't update
Hi, Just a small problem. I recently updated to Repetier-Server 1.0.2 and had problems so I rolled back to 0.94.3. now I don't seem to get a constant temperature reading from the hotend or the bed, nothing in graph or anywhere else, it will read the temp once then doesn't update.
Using a Pi 3b connected to a Prusa MK3s, I tried again reinstalling t
sudo dpkg -i Repetier-Server-0.94.3-Linux.debsudo dpkg -i Repetier-Server-0.94.3-Linux.deb
M115
and see if they start coming. Prusa supports autoreport temperatures so we do not need to query.
M155 S1
activates it. It gets automatically activated when M115 reports the capability. I guess something is gone wrong here. Does this always happen when you deactivate and activate printer in server?
I added M155 S1 to Run on Connect in Printer Settings>Event Dependent
Seems ok to me like this.....
Can you see any problem doing this?
Which firmware are you running? I'm currently on 3.9.1 I think.
I’m using the latest from Bear Labs FW3.9.3 which is slightly modded from the Prusa MK3S version.
https://github.com/bear-lab-3d/Prusa-Firmware/releases
