TimeLapse on usb pen drive
Hi, I have a USB 128gig thumb drive plugged into one of the Raspberry ports and am trying to get Repetier Server to record to that instead of filling up my main drive. Is there a feature or plugin for this or can you recommend a way to do that?
Tony
  • Server stores all data to /var/lib/Repetier-Server on linux. Timelapse is in a subdirectory of each printer. If you just have one printer one solution would be to create a link in the printer directory so timelapse in not s subdirectory but a link to a folder on your usb stick. Put you need to keep it mounted as long as the pi is on or it might get a different name or server tries to access the suddenly not available usb stick.
