Gerry
I have had Repetier 2.1.6 and under manual controls it had a flow rate. Since then I have had to redownload Repetier and now it does not have a Flow rate under the manual control. I have uninstalled Repetier and reinstalled it completely but the Flow rate control under the manual control is still missing? Has this happened to anyone else and how did you fix it?
What does the log say when eeprom sends M205? Any response or a message eeprom not supported?
When I ran M205 there is no errror it says OK and code or numbers after that.
M205 should return around a 100 lines with values and strings you would see in eeprom editor.
If it does have a 0 behind it how to I change it? I will just go there and confirm unless you recommend otherwise.
