Problem installing an Ender 3 Pro
Hello,
i want to connect an Ender 3 Pro with Repetier Server with an Rasberry pi Zero.
but i can´t connect it Online. Do i need to boot Marlin first or wich Firmware should I take.
I have connected the 3d printer with an mini usb cable to an adapter to micro usb for the pi Zero.
pls help me to connect it
  • Do you have a Pi Zero W and did you set up wifi on the Pi Zero?
  • edited January 2021
    yes it i did
  • i gonna set it up with Marlin and then I gonna try it again
  • You just connect printer and add a printer with the wizard in our gui. Then it should work. Just make sure to select marlin firmware. When you see a port /dev/serial/by-id/.. that is the printer to select.
    Yes I did. But I can´t see the port
  • Ok, that is a bit unexpected. Normally linux knows the drivers and creates port. So first check if you see the ender.
    Remove usb and run
    lsusb
    in ssh console. When plugin and run again to see if there is a new device. If not usb cable or device is not working. If it appears you know the name of the device and google about the drivers. A few are tricky and need to be added manually.
