Problem installing an Ender 3 Pro
i want to connect an Ender 3 Pro with Repetier Server with an Rasberry pi Zero.
but i can´t connect it Online. Do i need to boot Marlin first or wich Firmware should I take.
I have connected the 3d printer with an mini usb cable to an adapter to micro usb for the pi Zero.
pls help me to connect it
Yes I did. But I can´t see the port
Remove usb and run
lsusb
in ssh console. When plugin and run again to see if there is a new device. If not usb cable or device is not working. If it appears you know the name of the device and google about the drivers. A few are tricky and need to be added manually.
