Unable to use second extruder
Hello all
I have a XYZ davinci 2 duo that was working well using the 2 extruders with the stock firmware. I successfully printed 2 color parts several times.
Then I reflashed it and now I am using repetier host for windows version 1.5.4 with slic3r 1.2.9
On repetier Host I see two assignable extruders where I can assign the objects I load to the extruder I want to use.
Then I slice and print but the da vinci only heats and uses extruder one even if I assigned extruder 2 before slicing
On the da vinci I can clean, load, anything on extruder 2 so it is recognized by the da vinci repetier firmware and by repetier host but it just does not print using extruder 2
Please advice.
THANK YOU
Rod Magnus
Please advice.
THANK YOU
Rod Magnus
Is this a problem of cura or Repetier Host?
I don't want to change the filament every time I want to use the other color :-(
Is there a work around e.g. edit G-Code simply before starting printing?
Thank you.
Have you ensured no one else is using the serial port? Also that normally returns a different message.
