Which caused the regular expression to not match any more. You can revert that line and eeprom for repetier is working again. In 1.0.1 I added a trim operation to remove these extra whitespaces just in case it happens again.
Babystepping is a tiny bug when I fixed invert z handling. With inverted z axis it works, non inverted the factor was 0 not 1 so it stayed 0.
to
Thank you very much for the fast Update.
