Move cold extruder
Good morning
I am setting up a Delta printer with Ramps 1.4 card.
Repetier 1.0.4
I can't move the cold extruder to load the wire.
Without inserting the wire I tried to make a print and the extruder works.
After I have executed the M302 S1 command, the extruder moves a few steps in one direction and then stops.
I also tried with M302 S0 but I have the same behavior.
Configuration.h
