Layer Shift Problem
I use Repetier-Server 0.94.3 on my SW-X1 and Anycubic Chiron.
When I print I have some layer shift in random layer.
I check belt , motor , electronic system ...etc and I
can't find how it occur.
I only have this problem when i use Repetier-Server - I have used Octoprint, I do not have a problem here.
Is there any idea or what information I can provide to
improve this problem?
I have the fully paid version of Repetier-Server 0.94.3
You can check in console if you get communication errors but even if so firmware should prevent loosing steps. This could at max cause short pauses until fixed and new version is send.
The values that need to be limited are jerk, acceleration, max feedrate. With increasing speed motors loose power so that problems get more likely. Jerk is a sudden direction change which puts big forces on motor. Normally 10-20 is no problem with good motors for xy. 0.5 for z. Acceleration 1000 (50-100 for z) is normally also no problem. Most printers can go 100-200mm/s(z 5-10mm/s) without loosing steps. Just to give you some typical limits. It also depends on the current you give to the motors whcih are adjustable with TMC2208.
