Dev2 - I can’t activate the Jam control
I can't activate the "Jam" detection (works fine with firmware V1).
I'm using an MKS RUMBA board.
I tested several pins including end stops
I tested the M602 P0 command
I tested JAM_METHOD 1 and 2
In any case, no warning. I can print without filament.
What have I forgotten?
Configuration_io.h:
IO_INPUT(IOJam1, PD14)
IO_INPUT(IOJam2, PD15)
STEPPER_SIMPLE(E1MotorBase, IOE1Step, IOE1Dir, IOE1Enable, endstopNone, endstopNone)
STEPPER_SIMPLE(E2MotorBase, IOE2Step, IOE2Dir, IOE2Enable, endstopNone, endstopNone)
STEPPER_OBSERVEABLE(E1Motor, E1MotorBase)
STEPPER_OBSERVEABLE(E2Motor, E2MotorBase)
TOOL_EXTRUDER(ToolExtruder1, 0, 0, 0, HeaterExtruder1, E1Motor, 1.75, 221.0, 20, 30, 1000, 40, "", "", &Fan1PWM)
TOOL_EXTRUDER(ToolExtruder2, 12, 0, 0, HeaterExtruder2, E2Motor, 1.75, 221.0, 20, 30, 1000, 40, "G1 A30", "G28 A", &Fan1PWM)
JAM_DETECTOR_HW(JamExtruder1, E1Motor, IOJam1, ToolExtruder1, 204, 10, 200)
JAM_DETECTOR_HW(JamExtruder2, E2Motor, IOJam2, ToolExtruder2, 204, 10, 200)
Configuration.h:
#define JAM_METHOD 1
#define JAM_STEPS 408
#define JAM_SLOWDOWN_STEPS 600
#define JAM_SLOWDOWN_TO 75
#define JAM_ERROR_STEPS 1000
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
Thanks for your help
to host software (repetier-server) which is then responsible to start the filament change. A ui solution on lcd is currently not implemented.
So I guess your solution does not check for the response and you missed that.
More generally, will V2 integrate compatibility with the functionalities of new equipment, and particularly those of touch screens? These features are particularly important given the reduction of those implemented natively in the Repetier interface.
Currently there is only the request pause solution implemented. I'm currently working on prompt support for server and host. When this is working I think I will try adding a hybrid method that also works with sd prints with connected lcd displays. But it is in deed a hard problem. How to know a host is listening and understanding and which solution to use. No idea how many I have now seen in marlin, but they have so many variants all with advantages and disadvantages.
