Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
General
mesh bed leveling
N1YDP
October 2020
in
General
can you add mesh bed leveling
Repetier
October 2020
Already there for several years:-) But you might mean distortion correction when you want to follow the non planar bed or fix errors from delta geometry.
N1YDP
October 2020
i dont see it
#define
NUM_EXTRUDER 3
#define
MOTHERBOARD 33
#include
"pins.h"
#undef
FAN_BOARD_PIN
#define
FAN_BOARD_PIN -1
#define
BOARD_FAN_SPEED 255
#define
FAN_THERMO_PIN -1
#define
FAN_THERMO_MIN_PWM 128
#define
FAN_THERMO_MAX_PWM 255
#define
FAN_THERMO_MIN_TEMP 45
#define
FAN_THERMO_MAX_TEMP 60
#define
FAN_THERMO_THERMISTOR_PIN -1
#define
FAN_THERMO_THERMISTOR_TYPE 1
#undef
X_MAX_PIN
#define
X_MAX_PIN -1
#undef
Y_MAX_PIN
#define
Y_MAX_PIN -1
#undef
Z_MAX_PIN
#define
Z_MAX_PIN -1
//#define COMPAT_PRE1
#define
BLUETOOTH_SERIAL -1
#define
BLUETOOTH_BAUD 250000
#define
MIXING_EXTRUDER 1
#define
DRIVE_SYSTEM 0
#define
XAXIS_STEPS_PER_MM 80
#define
YAXIS_STEPS_PER_MM 80
#define
ZAXIS_STEPS_PER_MM 400
#define
EXTRUDER_FAN_COOL_TEMP 50
#define
PDM_FOR_EXTRUDER 0
#define
PDM_FOR_COOLER 0
#define
DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define
DECOUPLING_TEST_MIN_TEMP_RISE 1
#define
KILL_IF_SENSOR_DEFECT 1
#define
RETRACT_ON_PAUSE 2
#define
PAUSE_START_COMMANDS ""
#define
PAUSE_END_COMMANDS ""
#define
SHARED_EXTRUDER_HEATER 0
#define
EXT0_X_OFFSET 0
#define
EXT0_Y_OFFSET 0
#define
EXT0_Z_OFFSET 0
#define
EXT0_STEPS_PER_MM 100
#define
EXT0_TEMPSENSOR_TYPE 1
#define
EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define
EXT0_HEATER_PIN HEATER_0_PIN
#define
EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define
EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define
EXT0_INVERSE 1
#define
EXT0_ENABLE_PIN ORIG_E0_ENABLE_PIN
#define
EXT0_ENABLE_ON 0
#define
EXT0_MIRROR_STEPPER 0
#define
EXT0_STEP2_PIN ORIG_E0_STEP_PIN
#define
EXT0_DIR2_PIN ORIG_E0_DIR_PIN
#define
EXT0_INVERSE2 0
#define
EXT0_ENABLE2_PIN ORIG_E0_ENABLE_PIN
#define
EXT0_MAX_FEEDRATE 50
#define
EXT0_MAX_START_FEEDRATE 20
#define
EXT0_MAX_ACCELERATION 5000
#define
EXT0_HEAT_MANAGER 1
#define
EXT0_WATCHPERIOD 1
#define
EXT0_PID_INTEGRAL_DRIVE_MAX 230
#define
EXT0_PID_INTEGRAL_DRIVE_MIN 40
#define
EXT0_PID_PGAIN_OR_DEAD_TIME 4
#define
EXT0_PID_I 2
#define
EXT0_PID_D 40
#define
EXT0_PID_MAX 255
#define
EXT0_ADVANCE_K 0
#define
EXT0_ADVANCE_L 0
#define
EXT0_ADVANCE_BACKLASH_STEPS 0
#define
EXT0_WAIT_RETRACT_TEMP 150
#define
EXT0_WAIT_RETRACT_UNITS 0
#define
EXT0_SELECT_COMMANDS ""
#define
EXT0_DESELECT_COMMANDS ""
#define
EXT0_EXTRUDER_COOLER_PIN -1
#define
EXT0_EXTRUDER_COOLER_SPEED 255
#define
EXT0_DECOUPLE_TEST_PERIOD 12000
#define
EXT0_JAM_PIN -1
#define
EXT0_JAM_PULLUP 0
#define
EXT1_X_OFFSET 0
#define
EXT1_Y_OFFSET 0
#define
EXT1_Z_OFFSET 0
#define
EXT1_STEPS_PER_MM 100
#define
EXT1_TEMPSENSOR_TYPE 1
#define
EXT1_TEMPSENSOR_PIN TEMP_1_PIN
#define
EXT1_HEATER_PIN 7
#define
EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define
EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define
EXT1_INVERSE 1
#define
EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
EXT1_ENABLE_ON 0
#define
EXT1_MIRROR_STEPPER 0
#define
EXT1_STEP2_PIN ORIG_E1_STEP_PIN
#define
EXT1_DIR2_PIN ORIG_E1_DIR_PIN
#define
EXT1_INVERSE2 0
#define
EXT1_ENABLE2_PIN ORIG_E1_ENABLE_PIN
#define
EXT1_MAX_FEEDRATE 50
#define
EXT1_MAX_START_FEEDRATE 20
#define
EXT1_MAX_ACCELERATION 5000
#define
EXT1_HEAT_MANAGER 1
#define
EXT1_WATCHPERIOD 1
#define
EXT1_PID_INTEGRAL_DRIVE_MAX 230
#define
EXT1_PID_INTEGRAL_DRIVE_MIN 40
#define
EXT1_PID_PGAIN_OR_DEAD_TIME 4
#define
EXT1_PID_I 2
#define
EXT1_PID_D 40
#define
EXT1_PID_MAX 255
#define
EXT1_ADVANCE_K 0
#define
EXT1_ADVANCE_L 0
#define
EXT1_ADVANCE_BACKLASH_STEPS 0
#define
EXT1_WAIT_RETRACT_TEMP 150
#define
EXT1_WAIT_RETRACT_UNITS 0
#define
EXT1_SELECT_COMMANDS ""
#define
EXT1_DESELECT_COMMANDS ""
#define
EXT1_EXTRUDER_COOLER_PIN -1
#define
EXT1_EXTRUDER_COOLER_SPEED 255
#define
EXT1_DECOUPLE_TEST_PERIOD 12000
#define
EXT1_JAM_PIN -1
#define
EXT1_JAM_PULLUP 0
#define
EXT2_X_OFFSET 0
#define
EXT2_Y_OFFSET 0
#define
EXT2_Z_OFFSET 0
#define
EXT2_STEPS_PER_MM 100
#define
EXT2_TEMPSENSOR_TYPE 1
#define
EXT2_TEMPSENSOR_PIN TEMP_2_PIN
#define
EXT2_HEATER_PIN HEATER_3_PIN
#define
EXT2_STEP_PIN ORIG_E2_STEP_PIN
#define
EXT2_DIR_PIN ORIG_E2_DIR_PIN
#define
EXT2_INVERSE 1
#define
EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define
EXT2_ENABLE_ON 0
#define
EXT2_MIRROR_STEPPER 0
#define
EXT2_STEP2_PIN ORIG_E2_STEP_PIN
#define
EXT2_DIR2_PIN ORIG_E2_DIR_PIN
#define
EXT2_INVERSE2 0
#define
EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
#define
EXT2_MAX_FEEDRATE 50
#define
EXT2_MAX_START_FEEDRATE 20
#define
EXT2_MAX_ACCELERATION 5000
#define
EXT2_HEAT_MANAGER 1
#define
EXT2_WATCHPERIOD 1
#define
EXT2_PID_INTEGRAL_DRIVE_MAX 230
#define
EXT2_PID_INTEGRAL_DRIVE_MIN 40
#define
EXT2_PID_PGAIN_OR_DEAD_TIME 7
#define
EXT2_PID_I 2
#define
EXT2_PID_D 40
#define
EXT2_PID_MAX 255
#define
EXT2_ADVANCE_K 0
#define
EXT2_ADVANCE_L 0
#define
EXT2_ADVANCE_BACKLASH_STEPS 0
#define
EXT2_WAIT_RETRACT_TEMP 150
#define
EXT2_WAIT_RETRACT_UNITS 0
#define
EXT2_SELECT_COMMANDS ""
#define
EXT2_DESELECT_COMMANDS ""
#define
EXT2_EXTRUDER_COOLER_PIN -1
#define
EXT2_EXTRUDER_COOLER_SPEED 255
#define
EXT2_DECOUPLE_TEST_PERIOD 12000
#define
EXT2_JAM_PIN -1
#define
EXT2_JAM_PULLUP 0
#define
FEATURE_RETRACTION 1
#define
AUTORETRACT_ENABLED 0
#define
RETRACTION_LENGTH 3
#define
RETRACTION_LONG_LENGTH 13
#define
RETRACTION_SPEED 40
#define
RETRACTION_Z_LIFT 0
#define
RETRACTION_UNDO_EXTRA_LENGTH 0
#define
RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define
RETRACTION_UNDO_SPEED 20
#define
FILAMENTCHANGE_X_POS 0
#define
FILAMENTCHANGE_Y_POS 0
#define
FILAMENTCHANGE_Z_ADD 2
#define
FILAMENTCHANGE_REHOME 1
#define
FILAMENTCHANGE_SHORTRETRACT 5
#define
FILAMENTCHANGE_LONGRETRACT 50
#define
JAM_STEPS 220
#define
JAM_SLOWDOWN_STEPS 320
#define
JAM_SLOWDOWN_TO 70
#define
JAM_ERROR_STEPS 500
#define
JAM_MIN_STEPS 10
#define
JAM_ACTION 1
#define
RETRACT_DURING_HEATUP true
#define
PID_CONTROL_RANGE 20
#define
SKIP_M109_IF_WITHIN 2
#define
SCALE_PID_TO_MAX 0
#define
TEMP_HYSTERESIS 0
#define
EXTRUDE_MAXLENGTH 160
#define
NUM_TEMPS_USERTHERMISTOR0 0
#define
USER_THERMISTORTABLE0 {}
#define
NUM_TEMPS_USERTHERMISTOR1 0
#define
USER_THERMISTORTABLE1 {}
#define
NUM_TEMPS_USERTHERMISTOR2 0
#define
USER_THERMISTORTABLE2 {}
#define
GENERIC_THERM_VREF 5
#define
GENERIC_THERM_NUM_ENTRIES 33
#define
HEATER_PWM_SPEED 0
#define
HAVE_HEATED_BED 1
#define
HEATED_BED_MAX_TEMP 120
#define
SKIP_M190_IF_WITHIN 3
#define
HEATED_BED_SENSOR_TYPE 1
#define
HEATED_BED_SENSOR_PIN TEMP_1_PIN
#define
HEATED_BED_HEATER_PIN HEATER_1_PIN
#define
HEATED_BED_SET_INTERVAL 5000
#define
HEATED_BED_HEAT_MANAGER 3
#define
HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define
HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define
HEATED_BED_PID_PGAIN_OR_DEAD_TIME 5
#define
HEATED_BED_PID_IGAIN 33
#define
HEATED_BED_PID_DGAIN 290
#define
HEATED_BED_PID_MAX 255
#define
HEATED_BED_DECOUPLE_TEST_PERIOD 300000
#define
MIN_EXTRUDER_TEMP 150
#define
MAXTEMP 275
#define
MIN_DEFECT_TEMPERATURE -10
#define
MAX_DEFECT_TEMPERATURE 290
// ## Laser configuration ##
automatically disabled.
#define
SUPPORT_LASER 0
#define
LASER_PIN 9
#define
LASER_ON_HIGH 1
// ## CNC configuration ##
#define
SUPPORT_CNC 0
#define
CNC_WAIT_ON_ENABLE 300
#define
CNC_WAIT_ON_DISABLE 0
#define
CNC_ENABLE_PIN -1
#define
CNC_ENABLE_WITH 1
#define
CNC_DIRECTION_PIN -1
#define
CNC_DIRECTION_CW 1
#define
DEFAULT_PRINTER_MODE 0
#define
ENDSTOP_PULLUP_X_MIN true
#define
ENDSTOP_X_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_X true
#define
ENDSTOP_PULLUP_Y_MIN true
#define
ENDSTOP_Y_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_Y true
#define
ENDSTOP_PULLUP_Z_MIN true
#define
ENDSTOP_Z_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_Z true
#define
ENDSTOP_PULLUP_X_MAX true
#define
ENDSTOP_X_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_X false
#define
ENDSTOP_PULLUP_Y_MAX true
#define
ENDSTOP_Y_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_Y false
#define
ENDSTOP_PULLUP_Z_MAX true
#define
ENDSTOP_Z_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_Z false
#define
max_software_endstop_r true
#define
min_software_endstop_x false
#define
min_software_endstop_y false
#define
min_software_endstop_z false
#define
max_software_endstop_x true
#define
max_software_endstop_y true
#define
max_software_endstop_z true
#define
ENDSTOP_X_BACK_MOVE 5
#define
ENDSTOP_Y_BACK_MOVE 5
#define
ENDSTOP_Z_BACK_MOVE 5
#define
ENDSTOP_X_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_X_BACK_ON_HOME 1
#define
ENDSTOP_Y_BACK_ON_HOME 1
#define
ENDSTOP_Z_BACK_ON_HOME 0
#define
ALWAYS_CHECK_ENDSTOPS 1
#define
X_ENABLE_ON 0
#define
Y_ENABLE_ON 0
#define
Z_ENABLE_ON 0
#define
DISABLE_X 0
#define
DISABLE_Y 0
#define
DISABLE_Z 0
#define
DISABLE_E 0
#define
INVERT_X_DIR 1
#define
INVERT_Y_DIR 0
#define
INVERT_Z_DIR 1
#define
X_HOME_DIR -1
#define
Y_HOME_DIR -1
#define
Z_HOME_DIR -1
#define
X_MAX_LENGTH 200
#define
Y_MAX_LENGTH 280
#define
Z_MAX_LENGTH 200
#define
X_MIN_POS 0
#define
Y_MIN_POS 0
#define
Z_MIN_POS 0
#define
DISTORTION_CORRECTION 0
#define
DISTORTION_CORRECTION_POINTS 5
#define
DISTORTION_CORRECTION_R 100
#define
DISTORTION_PERMANENT 1
#define
DISTORTION_UPDATE_FREQUENCY 15
#define
DISTORTION_START_DEGRADE 0.5
#define
DISTORTION_END_HEIGHT 1
#define
DISTORTION_EXTRAPOLATE_CORNERS 0
#define
DISTORTION_XMIN 10
#define
DISTORTION_YMIN 10
#define
DISTORTION_XMAX 190
#define
DISTORTION_YMAX 250
// ## Movement settings ##
#define
FEATURE_BABYSTEPPING 1
#define
BABYSTEP_MULTIPLICATOR 1
#define
DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves
#define
DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves
#define
EXACT_DELTA_MOVES 1
// Delta settings
#define
DELTA_HOME_ON_POWER 0
#define
DELTASEGMENTS_PER_PRINTLINE 24
#define
STEPPER_INACTIVE_TIME 360L
#define
MAX_INACTIVE_TIME 0L
#define
MAX_FEEDRATE_X 250
#define
MAX_FEEDRATE_Y 300
#define
MAX_FEEDRATE_Z 2
#define
HOMING_FEEDRATE_X 40
#define
HOMING_FEEDRATE_Y 40
#define
HOMING_FEEDRATE_Z 2
#define
HOMING_ORDER HOME_ORDER_XYZ
#define
ZHOME_MIN_TEMPERATURE 0
#define
ZHOME_HEAT_ALL 1
#define
ZHOME_HEAT_HEIGHT 20
#define
ZHOME_X_POS 999999
#define
ZHOME_Y_POS 999999
#define
ENABLE_BACKLASH_COMPENSATION 1
#define
X_BACKLASH 0
#define
Y_BACKLASH 0
#define
Z_BACKLASH 0
#define
RAMP_ACCELERATION 1
#define
STEPPER_HIGH_DELAY 0
#define
DIRECTION_DELAY 0
#define
STEP_DOUBLER_FREQUENCY 12000
#define
ALLOW_QUADSTEPPING 1
#define
DOUBLE_STEP_DELAY 0 // time in microseconds
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define
INTERPOLATE_ACCELERATION_WITH_Z 0
#define
ACCELERATION_FACTOR_TOP 100
#define
MAX_JERK 15
#define
MAX_ZJERK 0.3
#define
PRINTLINE_CACHE_SIZE 16
#define
MOVE_CACHE_LOW 10
#define
LOW_TICKS_PER_MOVE 250000
#define
EXTRUDER_SWITCH_XY_SPEED 100
#define
DUAL_X_AXIS 0
#define
FEATURE_TWO_XSTEPPER 0
#define
X2_STEP_PIN ORIG_E1_STEP_PIN
#define
X2_DIR_PIN ORIG_E1_DIR_PIN
#define
X2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_TWO_YSTEPPER 0
#define
Y2_STEP_PIN ORIG_E1_STEP_PIN
#define
Y2_DIR_PIN ORIG_E1_DIR_PIN
#define
Y2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_TWO_ZSTEPPER 0
#define
Z2_STEP_PIN ORIG_E1_STEP_PIN
#define
Z2_DIR_PIN ORIG_E1_DIR_PIN
#define
Z2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_THREE_ZSTEPPER 0
#define
Z3_STEP_PIN ORIG_E2_STEP_PIN
#define
Z3_DIR_PIN ORIG_E2_DIR_PIN
#define
Z3_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define
FEATURE_DITTO_PRINTING 0
#define
USE_ADVANCE 0
#define
ENABLE_QUADRATIC_ADVANCE 0
#define
BAUDRATE 250000
#define
ENABLE_POWER_ON_STARTUP 0
#define
POWER_INVERTING 0
#define
KILL_METHOD 1
#define
ACK_WITH_LINENUMBER 1
#define
WAITING_IDENTIFIER "wait"
#define
ECHO_ON_EXECUTE 1
#define
EEPROM_MODE 1
#undef
PS_ON_PIN
#define
PS_ON_PIN -1
#define
JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define
FEATURE_SERVO 0
#define
SERVO0_PIN 11
#define
SERVO1_PIN -1
#define
SERVO2_PIN -1
#define
SERVO3_PIN -1
#define
SERVO0_NEUTRAL_POS -1
#define
SERVO1_NEUTRAL_POS -1
#define
SERVO2_NEUTRAL_POS -1
#define
SERVO3_NEUTRAL_POS -1
#define
UI_SERVO_CONTROL 0
#define
FAN_KICKSTART_TIME 200
#define
FEATURE_WATCHDOG 1
#define
Z_PROBE_Z_OFFSET 0
#define
Z_PROBE_Z_OFFSET_MODE 0
#define
UI_BED_COATING 1
#define
FEATURE_Z_PROBE 1
#define
Z_PROBE_BED_DISTANCE 10
#define
Z_PROBE_PIN ORIG_Z_MIN_PIN
#define
Z_PROBE_PULLUP 0
#define
Z_PROBE_ON_HIGH 0
#define
Z_PROBE_X_OFFSET 20
#define
Z_PROBE_Y_OFFSET 20
#define
Z_PROBE_WAIT_BEFORE_TEST 0
#define
Z_PROBE_SPEED 3
#define
Z_PROBE_XY_SPEED 100
#define
Z_PROBE_SWITCHING_DISTANCE 1
#define
Z_PROBE_REPETITIONS 1
#define
Z_PROBE_HEIGHT 0.7
#define
Z_PROBE_START_SCRIPT ""
#define
Z_PROBE_FINISHED_SCRIPT ""
#define
Z_PROBE_REQUIRES_HEATING 0
#define
Z_PROBE_MIN_TEMPERATURE 150
#define
FEATURE_AUTOLEVEL 1
#define
Z_PROBE_X1 0
#define
Z_PROBE_Y1 0
#define
Z_PROBE_X2 180
#define
Z_PROBE_Y2 0
#define
Z_PROBE_X3 100
#define
Z_PROBE_Y3 180
#define
BED_LEVELING_METHOD 1
#define
BED_CORRECTION_METHOD 0
#define
BED_LEVELING_GRID_SIZE 5
#define
BED_LEVELING_REPETITIONS 5
#define
BED_MOTOR_1_X 0
#define
BED_MOTOR_1_Y 0
#define
BED_MOTOR_2_X 200
#define
BED_MOTOR_2_Y 0
#define
BED_MOTOR_3_X 100
#define
BED_MOTOR_3_Y 200
#define
BENDING_CORRECTION_A 0
#define
BENDING_CORRECTION_B 0
#define
BENDING_CORRECTION_C 0
#define
FEATURE_AXISCOMP 0
#define
AXISCOMP_TANXY 0
#define
AXISCOMP_TANYZ 0
#define
AXISCOMP_TANXZ 0
#ifndef
SDSUPPORT // Some boards have sd support on board. These define the values already in pins.h
#define
SDSUPPORT 1
#undef
SDCARDDETECT
#define
SDCARDDETECT SDSS
#define
SDCARDDETECTINVERTED 0
#endif
#define
SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define
SD_RUN_ON_STOP ""
#define
SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define
ARC_SUPPORT 1
#define
FEATURE_MEMORY_POSITION 1
#define
FEATURE_CHECKSUM_FORCED 0
#define
FEATURE_FAN_CONTROL 1
#define
FEATURE_FAN2_CONTROL 0
#define
FEATURE_CONTROLLER 2
#define
ADC_KEYPAD_PIN -1
#define
LANGUAGE_EN_ACTIVE 1
#define
LANGUAGE_DE_ACTIVE 0
#define
LANGUAGE_NL_ACTIVE 0
#define
LANGUAGE_PT_ACTIVE 0
#define
LANGUAGE_IT_ACTIVE 0
#define
LANGUAGE_ES_ACTIVE 0
#define
LANGUAGE_FI_ACTIVE 0
#define
LANGUAGE_SE_ACTIVE 0
#define
LANGUAGE_FR_ACTIVE 0
#define
LANGUAGE_CZ_ACTIVE 0
#define
LANGUAGE_PL_ACTIVE 0
#define
LANGUAGE_TR_ACTIVE 0
#define
UI_PRINTER_NAME "--3IN1OUT--"
#define
UI_PRINTER_COMPANY "HE3D"
#define
UI_PAGES_DURATION 4000
#define
UI_ANIMATION 0
#define
UI_SPEEDDEPENDENT_POSITIONING 0
#define
UI_DISABLE_AUTO_PAGESWITCH 1
#define
UI_AUTORETURN_TO_MENU_AFTER 30000
#define
FEATURE_UI_KEYS 0
#define
UI_ENCODER_SPEED 1
#define
UI_REVERSE_ENCODER 0
#define
UI_KEY_BOUNCETIME 20
#define
UI_KEY_FIRST_REPEAT 500
#define
UI_KEY_REDUCE_REPEAT 50
#define
UI_KEY_MIN_REPEAT 50
#define
FEATURE_BEEPER 0
#define
CASE_LIGHTS_PIN -1
#define
CASE_LIGHT_DEFAULT_ON 1
#define
UI_START_SCREEN_DELAY 1000
#define
UI_DYNAMIC_ENCODER_SPEED 1
#define
BEEPER_SHORT_SEQUENCE 2,2
#define
BEEPER_LONG_SEQUENCE 8,8
#define
UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
#define
UI_SET_PRESET_EXTRUDER_TEMP_PLA 210
#define
UI_SET_PRESET_HEATED_BED_TEMP_ABS 90
#define
UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define
UI_SET_MIN_HEATED_BED_TEMP 30
#define
UI_SET_MAX_HEATED_BED_TEMP 120
#define
UI_SET_MIN_EXTRUDER_TEMP 170
#define
UI_SET_MAX_EXTRUDER_TEMP 260
#define
UI_SET_EXTRUDER_FEEDRATE 2
#define
UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#define
NUM_MOTOR_DRIVERS 0
Repetier
October 2020
Read better:-) From your config posted:
#define
#define
#define
#define
#define
#define
#define
#define
#define
DISTORTION_XMIN 10
#define
DISTORTION_YMIN 10
#define
DISTORTION_XMAX 190
#define
DISTORTION_YMAX 250
It is controlled by G33 command which must be send AFTER G32 if you want it enabled for current bed shape.
Sign In
or
Register
to comment.
