Repetier host dont send M600 when sensor is Open
Hi, i've a strange problem:
it is as if the Repetier Host does not react to the signal coming from the printer when the sensor is turn on/off, and does not launch M600.
Would anyone know why?
I have a BTT skr 1.3 and Marlin 2.0 bugfix. I have enabled:
EMERGENCY_PARSER
Pin 1.25 (Zmin) is set for the Filament Runout Sensor.
I verified that the switch works by sending M119 from REPETIER HOST.
I send the M412 command before launching a test print: filament runout on
I launch the print and after a while I open the switch, I expect the print to stop and go park, but it doesn't.
To do a test i send the M600 command from the host while the print is proceeding. it works good. the print pauses and does everything that is enabled and set in Advanced Pause.
My other try test is setting different command for FILAMENT RUNOUT SENSOR. I had try with M410. Equally Don't work.
FILAMENT_RUNOUT_SENSOR
ADVANCED_PAUSE_FEATURE
NOZLE_PARK_FEATUREEMERGENCY_PARSER
the firmware should respond with the instructions set in advanced pause and nozzle park feature:
