XYZ Control Speed and WEBCAM
a couple of questions.
1/ i find the XYZ control speed really slow on my Prusa MK3s, is there a way to speed up?
2/ can I alter focus and exposure setting manually instead of using AF and Auto Exposure ?
3/ can I alter preview thumbnail size ?
4/ the home button does a bed calibration, is it possible to redefine so the extruder just moves to the HOME position without calibration?
Cheers
2) You can use the mjpg_streamer url manually. It has a web interface allowing to change some values. You can also add the settings in some script so they get set on startup. Just don't know exactly the commands. v4l....
3) No.
Can you tell me what config file I need to edit in my Rasberry Pi ? I checked the OctoPrint stuff for setting webcam parameters like manual exposure, focus etc which is specific to OctoPrint. This should be pretty basic stuff for you, for me it will take me hours of research. Thanks
T
https://www.kurokesu.com/main/2016/01/16/manual-usb-camera-settings-in-linux/
Once you have the command to change them add them all into /usr/local/Repetier-Setup/bin/startAllCams
at the end and they will always be active after reboot.
