Change Timelapse Settings on Repetier Touchscreen
Hi, i wanted to change the timelapse options from the raspberry touch overview directly
Since the Raspberry is directly attached to the Printer and the PC or smartphone is not in reach
So it would be nice to change the settings if a timelapse for the next print should be generated or not...
i had a layershift on a previous print because of lost steps... thats why the different moving speed
Moving should never cause lost steps or your maximm speed in firmware is defined too high. That is what the max speed is for. Motion in timelapse uses xy move speed defined in manual control I think, so there you can also reduce it.
