M221 and Advanced Ditto Printing
M221 used with Ditto Printing
This question is for advanced Ditto Printing.
I am involved with a manufacturing start up for small 3D printed pieces.
We have a part that has tight tolerances for the parts to work and fit correctly.
Condition:
We use 3 different filament PLA colors, on one printer, printing 3 parts at one time in Ditto Printing, using Simplify 3D as the slicer.
Situation:
Simplify 3D allows for separate Extrusion Multipliers for each extruder, but Repetier only uses settings for T0 and ignores Extrusion Multiplier settings for T1 and T2.
I tried to use M221 in all of its configurations to separate each individual extruder, but it only uses all the settings from a single setting, the last M221 in the command line.
Question: is there a way to address each individual extruders, Extrusion Multiplier?
The reason for this separation, is to have each extruder head to be independent from each other. This allows different Density Filaments to be printed at the same time on the same printer.
The only other way, at this moment is to change the extruders steps per each different filament. This is not a logical solution for commercial printing configurations.
In V1 firmware ditto printing means the extruder steps from T0 get copied 1:1 to T1/T2 so even changing steps per mm will have no effect here.
In V2 firmware there is a module to equalize all extruders to same steps per mm while maintaining different resolutions. This would be the only solution within our firmwares that would help with different required resolutions.
So if you need different steps only V2 can help you here.
3 Extruders on Tool0 to Ditto Print.
Printer is calibrated with all Extruders set the same inEEPROM.
Filament on Extruder 3, is 1.78 mm compared to 1.75 mm on Extruder 1&2.
Proposed Solution:
Add M92 E40.5:40.5:38.225 (Preprint process)
Expected Results:
Ditto Printing clones all info on T0 (except current settings set on M92). Each Extruder maintains its set Esteps set in M92. When printer is reset or powered off, all settings revert back to EEPROM.
Is this viable? or will All Extruders use E40.5, derived from T0, and override any M92 settings?
So how does V2 help? What module are you referring to?
Since STACKER uses Repetier, I would think that they would have noticed this problem. No doubt if they used three different colors, there would have been a noticeable dimensional difference between their parts being printed at the same time.
https://docfirmwarev2.repetier.com/config/motors#stepper_adjustable
If you check the dual x/stacker example you see how to use it as I added it there for ditto printing to solve that problem. At least the resolution difference. For bulk production I assume identical material and behaviour for all nozzles, but of course this makes it also adjustable.
Our printer is specific to printing one specific product. Our product can’t be printed without the afore mentioned modifications.
We are currently in the process of converting over to Rumba32’s from standard Rumba and Rumba+. We just haven’t made it to that point in the punch list. We are still working on perfecting a smooth manufacturing process, that has the necessary qualities, and time saving procedures in printing our product.
Will a three Extruder setup on one Tool, address each extruders Extrusion multiplier in Ditto mode for S3D?
I think the modules are great, as long as you maintain a smooth selection process for those modifications. I do like the firmware selection process of Repetier, but some of the settings for the motors, are a bit overwhelming.
One of the problems we want to solve. In V1 we are not flexible so all modules of one kind are merged into one big containing all settings possible, regardless if you need them or not. In V2 you only set what is needed for your special problem.
Not sure what you mean here. All extruders will extrude the same amount in distance. Ditto is copying to extruder 2 and 3. The only additional thing is that each extruder has it's own resolution to adjust for different steps per mm. If you need for example T1 to be 1.1*T0 you need to increase steps per MM for T1 by factor 1.1 to do so. M221 is still working with same amount on all extruders just as it was always designed to do. If you want a command that sets these like M2222 Axxx Bxxx Cxxx setting these factors you can write an extra command that does the setting. For example you can double the resolution adjustments. One is for real resolution and one for your material difference setable with e.g. M2222. With teh event system you can also add any extra Mcode you like. But if you want very special behaviour you will in the end always need to write a bit, also not really much.
Will Ditto still default to T0 across all extruders?
