I need add plugin to repeater host to enable a new tab on age interface.
I have a BoXZY multi-material fab machine. Its native windows software is a customized version of Repetier host. (an old one)
I wish to add control tabs to the current version of Repetier Host for mac to enable control of some of the machine functions (Laser and CNC)
because the machine does not implement these controls in the standard way, i am told the best way to do this is with a plug in.
I have the plug in files, but don't know where to put them on my mac.
I assumed based on some other posts i searched i would need to create a plugins directory in the hidden install directory, then have a correctly named folder underneath that with the correct BoXZY plugin files to get the tab to show up, but i am having no luck adding plugins to repetier host.
the page you suggested referencing plugins for the current version has an example, but doesn't instruct me where it belongs.
In terms of software, the box Includes Autodesk Fusion 360 Cloud Based 3D CAD Platform with Boxzy Interface which is quiet stable.
The main thing that makes BoXZY Complete so much advanced is that it comes with additional features and products in the box. The BoXZY Complete carries a high fidelity laser engraver that allows you to carve anything. With this, you can carve any material hard or soft that exists and metals as hard as titanium. The BoXZY Complete comes with a precision of hundred CNC machines and makes it possible to work more efficiently. The machine carries all the features that you wished a CNC machine should have.
Thanks to bill for providing comprehensive information on this boxyz CNC.
