about license
hello Repetier
i just would ask if there is a way to how many licenses had been registered from those i paid
i have lost a sd card containing repetier server and do not remember if there was a license onto it
if i understand that license is embedded on raspberry itself , not on sd card ?
another question about license
i have a case : i own four raspberry for different uses. One of them ,installed as repetier server , as been loaded with sd card for NAS program by error. Reloading this same raspberry with repetier server sd card , server ask again for entering license. Question : is the previous license lost ?
thanks
after a long shutdown due to covid 19 I try to restart repetier server on raspberry which no longer works and claims the license key. I enter the license key and answer obtained "license server returned an error unknown license OJRZ .................. RR in request"
what i have to do before this last solution ?
but where i have to do that ? did my brain damaged by covid ? no more remembrances
merci d'avance
If it does not work send a mail to our support with the license key and we can reset it.
merci beaucoup !!!
ping licence.internetloesungen.com
with an answer internet and dns is up and working.
Which server version are you using?
The old root certificate expired on september 2021, so after that only systems with updated list can connect to many https sites.
