Using more Render Threads for Previews?
Im using Repetier Host for windows and im running an Ryzen 5 CPU with 8 threads. Because the CPU is overkill for most of Repetier Server I woud like to use some of the unsused performance for a faster render of the previews. Is there some way to let Repetier use more threads for rendering?
  • No that is not possible.It is hard coded to use only one thread for normal rendering. Maybe future version will be able to that, but then you don't need to do anything. It will decide based on available cpu count.
