Qidi Tech X-MAX
Hi there.
I am very interested in the Qidi Tech X-MAX. The printer does not have a USB Port that can be connected to the Raspberry. But on the Mainboard inside the printer there is a UART connector where a USB Converter could be connected via cable. Now the question is: Is Repetier-Server compatible to the printer, since the printer does have Marlin Firmware. Has anyone made xperience with this?
But also note that this requires that Marlin was configured with that uart as serial - if not nothing will happen here.
And of course wrong wiring can damage hardware.
