Qidi Tech X-MAX
Hi there.
I am very interested in the Qidi Tech X-MAX. The printer does not have a USB Port that can be connected to the Raspberry. But on the Mainboard inside the printer there is a UART connector where a USB Converter could be connected via cable. Now the question is: Is Repetier-Server compatible to the printer, since the printer does have Marlin Firmware. Has anyone made xperience with this?
  • Server is compatible with Marlin. If it has a 3.3V UART you can even connect it directly to pi serial TX/RX pins. Make sure RX is connected to TX and vice versa and you also need same mass potential. Then /dev/ttypAMA0 would be serial to connect to.
    But also note that this requires that Marlin was configured with that uart as serial - if not nothing will happen here.
    And of course wrong wiring can damage hardware.
  • Thanks for that competent answer. That helps.
    Hi FriesenRudi - did you succeed in getting the X-Max connected to the Raspi/RepetierServer ? and how did you do that ? I am considering to buy a X-Plus, but just understand that they have some kind of proprietery firmware installed, PrusaSlicer won't work and stuff like that - that makes me wonder...
  • Hi Manfredo1962. I read at different places, that ProsaSlicer would work. I did not check that on my own. To get the Qidi X-MAX connected to Repetier Server will be a project for November. I will let you know.
