GRBL Support
I'm going to be setting up a CNC mini-mill from OpenBuilds. It will be driven by an Arduino setup running GRBL 1.1. I was wondering if I would be able to customize my RS to control it by creating a new XML file for the GRBL firmware and adding it to the /usr/local/RepetierServer/firmware folder? Is RS extensible that way, or does it take more to support a different firmware?
As a first test you could try connect with marlin firmware and see if communication in general is possible. If there are only minor problems in format let me know and I might be able to change that so grbl is also supported then.
any progress on this? I am just about to set up a laser cutter on GRBL and use server Pro for my 3D printers.and would like to stay with this rather than learning something new.
