Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
Feature Requests
Option to adjust the spacing between objects when printing multiple objects by autoposition
scott_lai
July 2020
in
Feature Requests
When using autoposition and PrusaSlicer, the distance between objects is too close, resulting in overlapping rafts.
Repetier
July 2020
Yes good idea to make it a variable in global settings.
scott_lai
July 2020
I think it’s more convenient to put it on the the toolbar of "Object Placement" tabbed panel
Repetier
July 2020
You only say that because you need it:-) But last 9 years worked without quite good. And since it is more a printer option maybe printer config would be a better place. But object placement should be kept clean.
Sign In
or
Register
to comment.
