Option to adjust the spacing between objects when printing multiple objects by autoposition
When using autoposition and PrusaSlicer, the distance between objects is too close, resulting in overlapping rafts.
  • Yes good idea to make it a variable in global settings.
  • I think it’s more convenient to put it on the the toolbar of "Object Placement" tabbed panel
  • You only say that because you need it:-) But last 9 years worked without quite good. And since it is more a printer option maybe printer config would be a better place. But object placement should be kept clean.
