Fehlermeldung bei Deltadrucker
2»
  • edited March 2020
    Die 2D Vorschau fuer Objekte ist wie gesagt o.k.
    Da sind die Objekte immer mittig :)
    StartCode:
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{speed_travel} ;move the platform down 15mm
    G92 E0 ;zero the extruded length
    G1 F200 E3 ;extrude 3mm of feed stock
    G92 E0 ;zero the extruded length again
    G1 F{speed_travel}
    G0 Y20 F{speed_travel}
    M117 Printing...
    G5
    Endcode:
    M104 S0 ; turn off extruder
    M140 S0 ; turn off bed
    M84 ; disable motors
    M107
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 ;X-20 Y-20 F{speed_travel} ;move Z up a bit and retract filament even more
    G28 X0 ;Y0 ;move X/Y to min endstops, so the head is out of the way
    G1 Y180 F2000
    M84 ;steppers off
    G90
    M300 P300 S4000
    gincode des leeren gcodes:
    analysed: 1
    analysisTime: 0.003958
    created: 1584007233153
    extruder0: 0
    extruder1: 0
    extruder10: 0
    extruder11: 0
    extruder12: 0
    extruder13: 0
    extruder14: 0
    extruder15: 0
    extruder16: 0
    extruder17: 0
    extruder18: 0
    extruder19: 0
    extruder2: 0
    extruder20: 0
    extruder21: 0
    extruder22: 0
    extruder23: 0
    extruder24: 0
    extruder25: 0
    extruder26: 0
    extruder27: 0
    extruder28: 0
    extruder29: 0
    extruder3: 0
    extruder30: 0
    extruder31: 0
    extruder4: 0
    extruder5: 0
    extruder6: 0
    extruder7: 0
    extruder8: 0
    extruder9: 0
    extruderVolume0: 0
    extruderVolume1: 0
    extruderVolume10: 0
    extruderVolume11: 0
    extruderVolume12: 0
    extruderVolume13: 0
    extruderVolume14: 0
    extruderVolume15: 0
    extruderVolume16: 0
    extruderVolume17: 0
    extruderVolume18: 0
    extruderVolume19: 0
    extruderVolume2: 0
    extruderVolume20: 0
    extruderVolume21: 0
    extruderVolume22: 0
    extruderVolume23: 0
    extruderVolume24: 0
    extruderVolume25: 0
    extruderVolume26: 0
    extruderVolume27: 0
    extruderVolume28: 0
    extruderVolume29: 0
    extruderVolume3: 0
    extruderVolume30: 0
    extruderVolume31: 0
    extruderVolume4: 0
    extruderVolume5: 0
    extruderVolume6: 0
    extruderVolume7: 0
    extruderVolume8: 0
    extruderVolume9: 0
    fileSize: 0
    gcodePatch: {}
    lastPrintingTime: 0
    layer: 0
    lines: 0
    material0:
    material1:
    material10:
    material11:
    material12:
    material13:
    material14:
    material15:
    material16:
    material17:
    material18:
    material19:
    material2:
    material20:
    material21:
    material22:
    material23:
    material24:
    material25:
    material26:
    material27:
    material28:
    material29:
    material3:
    material30:
    material31:
    material4:
    material5:
    material6:
    material7:
    material8:
    material9:
    notes:
    printed: 0
    printingTime: 0
    radius: 0
    radiusMove: 0
    slicer: Unknown Slicer
    totalFilament: 0
    totalVolume: 0
    version: 2
    xMax: 215
    xMaxMove: 215
    xMin: 215
    xMinMove: 215
    yMax: 215
    yMaxMove: 215
    yMin: 215
    yMinMove: 215
    zMax: 0
    zMin: 0
  • G91 ;relative positioning
    G90 ; ---------- hier einfügen ------------
    G1 Y180 F2000
    Ich nehme an du hast xy home position auf 215 eingestellt? G28 setzt nicht automatisch auf absolute Positionen zurück. Marlin macht das vermutlich, aber nicht alle firmwares machen das, hilf hier dem server mit einem definitiven Wechsel.
  • G90 steht ja momentan eine zeile drunter.
    also nur eine Zeile hochschieben?
  • 2 Zeilen hochschieben aber ja. Muss nach dem G28 aber vor dem folgenden G1 mit absoluten Koordinaten stehen.
  • So bin inzwischen auf den Raspberry umgestiegen, weil ich auch noch ein paar Relays ansteuern wollte. (Licht bla bla)
    Leider hat das hochschieben nichts gebracht.
    Im Startcode steht es auch, auch dort hatte ich es hochgeschoben, Druckfeld bleibt rot.
  • Was ist denn im gcode gin file als Bereich ausgegeben und was hast du im server als xyz min/max udn als Druckbereich definiert?
  • edited April 2020
    Anbei: (Hatte ich schonmal von ner anderen gcodefile gepostet)
    ;FLAVOR:Marlin
    ;TIME:19070
    ;Filament used: 12.3633m
    ;Layer height: 0.2
    ;MINX:13.928
    ;MINY:15.991
    ;MINZ:0.2
    ;MAXX:198.373
    ;MAXY:196.072
    ;MAXZ:25.4
    ;Generated with Cura_SteamEngine 4.5.0
    M140 S60
    Bei mir in der config:
    https://i.imgur.com/O6xtDVX.png
  • Das ist was cura ausgibt, nicht die .gin Datei die der Server berechnet. Im Server ist es soweit korrekt eingestellt - wenn unter Druckerform die gleichen Koordinaten stehen sollte es also passen.
    Vielleicht zeigst du auch noch mal den korrigierten end gcode den du jetzt bekommst - der war ja eine bekannte Ursache das Problems.
  • totalVolume: 12346.28793695117
    version: 2
    xMax: 167.64999389648438
    xMaxMove: 161.0500030517578
    xMin: 42.36899948120117
    xMinMove: 0
    yMax: 57.37300109863281
    yMaxMove: 196.9969940185547
    yMin: 8.932999610900879
    yMinMove: 13.652999877929688
    zMax: 6.800000190734863
    zMin: 0
    das ist aus der gindatei
  • Zwar nicht die Konfiguration des Betts die noch fehlte aber es sieht Falsch aus daher nehme ich an das die Bettposition auch falsch Konfiguriert wurde.
  • Leider was anderes grade nach einem Neustart des RPi startet der Server nicht mehr.
    -Daten sind da.
    ****@raspberrypi:/var/lib/Repetier-Server$ ls -la
    total 44
    drwxr-xr-x 11 repetierserver dialout 4096 Apr 20 00:54 .
    drwxr-xr-x 32 root           root    4096 Apr 20 00:54 ..
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 15:44 configs
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 15:44 database
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 00:54 licenses
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 20:51 logs
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 00:54 lua
    drwxr-x---  3 repetierserver dialout 4096 Apr 20 00:57 printer
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 00:54 projects
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 00:54 reports
    drwxr-x---  2 repetierserver dialout 4096 Apr 20 15:21 tmp
    unter :
    ****@raspberrypi:/etc/init.d$ ls -la gibt es kein "RepetierServer"
    Installiert nach anleitung mit:
    sudo dpkg -i NewRepetierServerVersion.deb
    Bis Reboot ging es auch.
  • /etc/init.d ist veraltet - das startup script nutzt jetzt normalerweise systemd und steht und /lib/systemd/system/RepetierServer.service
    Teste erst mal ob er nicht läuft:
    ps aux | grep tier
    Wenn nicht starte manuell und sieh mal wo er auf die Nase fällt:
    sudo /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    Dateien da ist nämlich relativ - Wenn eine Datei korrupt ist kann es den start verhindern.
  • Resbpi war vollgelaufen... -.-
  • Ja das ist ein Problem, wobei er das ja im Userinterface anzeigt :-) Aber das Problem hab ich schon mehrfach gesehen. Vergesse es immer wieder.
  • edited April 2020
    Naja nach dem Neustart ging das Userinterface ja nicht ^^ Aber das Problem konnte ich ja dann schnell beheben.
    Druckerform liegt jetzt bei:
    X Links 0
    Y Vorne 0
    XRechts 215
    Y Hinten 215
    Sieht jetzt auch besser aus. Meldung kommt leider noch ^^
    https://imgur.com/kSLZvjy
    Sieht jetzt aber besser aus.
  • Mit meldung meinst du außerhalb des Druckbereichs?
    Für
    version: 2
    xMinMove: 0
    zMin: 0
    sollte das nicht mehr der fall sein. Wenn wir von einer anderen gcode Datei reden wonach es in dem Bild aussieht müstest du erneut gin checken - nicht das sich der G28 bug wieder eingeschlichen hat. Aber du weist ja das du trotzdem Drucken kannst.
  • edited April 2020
    Vollständigkeitshalber:
    Aktueller Gincode (vom Screenshot):
    printed: 3
    printingTime: 1003.1195910829205
    radius: 288.522216796875
    radiusMove: 0
    slicer: CuraEngine
    totalFilament: 286.6767272949219
    totalVolume: 689.5383362628072
    version: 2
    xMax: 205.89999389648438
    xMaxMove: 197.99000549316406
    xMin: 4.099999904632568
    xMinMove: 0
    yMax: 205.89999389648438
    yMaxMove: 197.5500030517578
    yMin: 4.099999904632568
    yMinMove: 5.934999942779541
    zMax: 0.20000000298023224
    zMin: 0
    Aber ja. Dann lassen wir es wie es ist - wenn wir es nicht hinbekommen.
    Kann ich die meldung in der xml unterdrücken?^^
    Man kann ja nicht alles lösen :)
  • Exportier mal deine Druckerkonfiguration und den gcode und schick sie mir. Er vergleicht halt die min/max aus .gin mit Druckerabmessungen. Ich seh aus deinen angaben den Fehler nicht aber er sollte bei dem was ich weiß auch nicht passieren. Also entweder haben wir was übersehen oder es gibt ein Problem da sich nicht kenne.
  • Okey das mach ich.
    Ist Dropbox okey für dich?
  • Klar schick mir pm mit dropbox link.
  • edited July 2020
    Hallo,
    ich muss jetzt hier auch noch mitmischen.
    Ich habe gerade meinen neuen Ender 3 bekommen, zusammengebaut, in Repetier Server aufgenommen, alles wunderbar- mit Repetier Server Pro 0.91.1. auf einem Raspberry.
    Dann bin ich auf die glorreiche Idee gekommen, das aktuelle 0.94.1 zu installieren- und seitdem habe ich auch das Problem mit dieser Fehlermeldung, mit unveränderten gcode-Dateien. An denen kann es demnach eigentlich nicht liegen.
    Nach dem ersten Start der neuen Version waren die Druckerabmessungen verstellt (X-Max und Y-Max), die habe ich korrigiert, so dass der Kringel wieder grün geworden ist.
    Die Fehlermeldung bleibt.
    X-Min und Y-Min auf 0 (rot!), X-Max und Y-Max auf 235, Z-Max=250.
    Warum X-Min=0 und Y-Min=0 falsch sein soll, versteh ich nicht. Und woher die richtigen Werte nehmen?
    Wie gesagt: mit der vorigen Version mit denselben Einstellungen war alles paletti.
  • Ich habe das Problem gelöst durch die Halbierung der werte, dann hat's Funktioniert.
  • Halbierung der Werte hat nichts gebracht, aber es hat sich jetzt komischerweise von selber behoben- mit unveränderten Einstellungen!
  • edited November 2020
    habe das selbe problem mit derr fehlermeldung. ich habe es so gelösst:
    ein
    am anfang vom startcode und ein
    am ende des startcodes und repetier überprüft das nicht mehr.
    nicht gerade "sauber" die lösung, aber es funktioniert (zumindest bei mir) ;)
    ps: bitte auf alle fälle das führende ; miteintragen
