All printer disconnection
It has happened to me a couple of times that the 4 printers that I have connected stop and I lose all my jobs.
This happened after I turned off one of the printers to restart it while the others were working.
Despite having turned it off, the LCD screen was still on, although with less intensity. What makes me think: Could it be that the raspberry pi tries to power the printer and it falls short?
When all the work stopped I did 2 things. One was to turn off the printer and another to disconnect the usb cable from the printer. But I don't remember the order now.
Could it be that rasperry with Repetier is so sensitive to this kind of operations?
PD: the reason I disconnected the one printer it is because the work I was doing was stopped, as if on pause, but every 10 seconds it moved a little.
I have a question: I need more usb ports and i plan to buy a usb hub. In this case the hub needs to be self powered? since it will not feed any printer. Or does the hub itself consumes power? What would you recommend.
