Manual Feed Rate Changes when print starts V1.54
I have 2 delta printers. One uses v0.91 firmware and the other uses v0.92 firmware. When printing with the printer that uses the v0.92 firmware, the feed rate control on the Host manual control tab changes from whatever I preset it to back to 100% when the print job starts. Once the job has started I must to change the setting back to what I had set prior to starting the job.
When I use the printer that has v9.01 firmware installed, this does not happen. The value always stays where I manually set it prior to the start of the print job. Is there a setting that I have incorrectly configured somewhere ? I have cloned the Slic3r slicer settings from the first printer so they should be set up to slice identically.
Here is a log. I have manually set the Feedrate to 85% (highlighted in red). As soon as the print job starts, the rate resets itself to 100 %. The version of the firmware is actually 0.92.2 if that helps
Log:
09:21:45.249 : N2599 M105 *48
09:21:48.260 : N2600 M105 *51
09:21:48.665 : N2601 M111 S15 *64
09:21:48.665 : Echo:N2601 M111 S15
09:21:51.317 : N2602 M105 *49
09:21:51.317 : Echo:N2602 M105
09:21:54.375 : N2603 M105 *48
09:21:54.375 : Echo:N2603 M105
09:21:55.170 : N2604 M220 S85 *77
09:21:55.170 : Echo:N2604 M220 S85
09:21:57.432 : N2605 M105 *54
09:21:57.432 : Echo:N2605 M105
09:21:57.651 : N2606 M117 ETE 00s *17
09:21:57.666 : Echo:N2606 M117 ETE 00s
09:21:58.041 : N2607 G28 *0
09:21:58.041 : N2608 G1 Z5 F5000 *24
09:22:01.816 : X:0.00 Y:0.00 Z:74.269 E:0.0000
09:22:01.816 : Echo:N2607 G28
09:22:01.832 : Echo:N2608 G1 Z5.00
F5000.00
09:22:01.832 : N2609 M105 *58
09:22:01.832 : N2610 G21 *15
09:22:01.832 : Echo:N2609 M105
09:22:01.832 : N2611 G90 *4
09:22:01.832 : Echo:N2610 G21
09:22:01.832 : N2612 M82 *14
09:22:01.847 : Echo:N2611 G90
09:22:01.847 : Echo:N2612 M82
09:22:01.847 : N2613 G92 E0 *81
09:22:01.847 : N2614 G1 E-1 F3600 *35
09:22:01.847 : Echo:N2613 G92
E0.0000
09:22:01.847 : N2615 G92 E0 *87
09:22:01.847 : Echo:N2614 G1
E-1.0000 F3600.00
09:22:01.847 : N2616 G1 Z0.2 F7800 *4
09:22:01.863 : Echo:N2615 G92
E0.0000
09:22:01.863 : N2617 G1 X-22.047 Y-15.521 F7800 *83
09:22:01.863 : Echo:N2616 G1 Z0.20
F7800.00
09:22:01.863 : N2618 G1 E1.1 F3600 *29
09:22:01.879 : Echo:N2617 G1 X-22.05
Y-15.52 F7800.00
09:22:01.879 : Printing layer 1 of 40
09:22:01.879 : N2619 G1 X-21.324 Y-16.548 E1.11765 F900 *44
09:22:01.879 : Echo:N2618 G1 E1.1000
F3600.00
09:22:01.879 : N2620 G1 X-20.774 Y-17.234 E1.13 *66
09:22:01.879 : Echo:N2619 G1 X-21.32
Y-16.55 E1.1176 F900.00
09:22:01.879 : N2621 G1 X-19.082 Y-19.09 E1.1653 *118
I am printing through host 1..54.
Here is the log with the ACK turned on . You can see where I set the speed to 85%. You can also see where the speed is reset to 100 % . Where is that coming from? It is not in the G Code. There is no starting script..
log2:
07:34:11.455 : T:23.23 /0 @:0
07:34:12.453 : wait
07:34:13.451 : wait
07:34:14.450 : wait
07:34:14.512 : N178 M105 *9
07:34:14.512 : ok 178
07:34:14.512 : T:23.23 /0 @:0
07:34:14.902 : N179 M220 S80 *119
07:34:14.902 : ok 179
07:34:14.902 : SpeedMultiply:80
07:34:15.905 : wait
07:34:16.909 : wait
07:34:17.580 : N180 M105 *14
07:34:17.580 : ok 180
07:34:17.580 : T:23.23 /0 @:0
07:34:18.578 : wait
07:34:19.577 : wait
07:34:20.575 : wait
07:34:20.637 : N181 M105 *15
07:34:20.637 : ok 181
07:34:20.637 : T:23.33 /0 @:0
07:34:21.636 : wait
07:34:22.634 : wait
07:34:23.633 : wait
07:34:23.695 : N182 M105 *12
07:34:23.695 : ok 182
07:34:23.695 : T:23.33 /0 @:0
07:34:23.945 : N183 M220 S85 *119
07:34:23.945 : ok 183
07:34:23.945 : SpeedMultiply:85
07:34:24.943 : wait
07:34:25.946 : wait
07:34:26.741 : N184 M105 *10
07:34:26.741 : ok 184
07:34:26.741 : T:23.33 /0 @:0
07:34:27.506 : N185 M117 ETE 00s *47
07:34:27.506 : ok 185
07:34:27.802 : N186 G28 *60
07:34:27.802 : ok 186
07:34:27.802 : N187 G1 Z5 F5000 *42
07:34:31.640 : SpeedMultiply:100
07:34:31.640 : X:0.00 Y:0.00 Z:74.269 E:1.9694
07:34:31.640 : ok 187
07:34:31.640 : N188 M105 *6
07:34:31.640 : ok 188
07:34:31.640 : N189 G21 *58
07:34:31.640 : T:23.33 /0 @:0
07:34:31.655 : ok 189
07:34:31.655 : N190 G90 *56
07:34:31.655 : ok 190
07:34:31.655 : N191 M82 *48
07:34:31.655 : ok 191
07:34:31.655 : N192 G92 E0 *109
07:34:31.655 : ok 192
07:34:31.655 : N193 G1 E-1 F3600 *25
07:34:31.687 : ok 193
07:34:31.687 : N194 G92 E0 *107
07:34:31.687 : ok 194
07:34:31.687 : N195 G1 Z0.2 F7800 *58
07:34:31.702 : ok 195
07:34:31.702 : N196 G1 X-22.047 Y-15.521 F7800 *111
07:34:31.702 : ok 196
07:34:31.702 : N197 G1 E1.1 F3600 *47
07:34:31.718 : ok 197
07:34:31.718 : Printing layer 1 of 40
07:34:31.718 : N198 G1 X-21.324 Y-16.548 E1.11765 F900 *16
07:34:31.718 : ok 198
07:34:31.718 : N199 G1 X-20.774 Y-17.234 E1.13 *117
07:34:31.718 : ok 199
07:34:31.718 : N200 G1 X-19.082 Y-19.09 E1.1653 *67
07:34:31.718 : ok 200
07:34:31.718 : N201 G1 X-18.45 Y-19.702 E1.17766 *116
07:34:31.733 : ok 201
07:34:31.733 : N202 G1 X-16.539 Y-21.332 E1.21295 *71
07:34:31.733 : ok 202
07:34:31.733 : N203 G1 X-15.836 Y-21.859 E1.22531 *75
07:34:31.749 : ok 203
07:34:31.749 : N204 G1 X-13.735 Y-23.236 E1.26061 *67
07:34:31.749 : ok 204
07:34:31.749 : N205 G1 X-12.971 Y-23.671 E1.27297 *64
07:34:31.749 : ok 205
07:34:31.749 : N206 G1 X-10.715 Y-24.775 E1.30826 *73
07:34:31.765 : ok 206
07:34:31.765 : N207 G1 X-9.902 Y-25.11 E1.32062 *70
07:34:31.765 : ok 207
07:34:31.765 : N208 G1 X-7.525 Y-25.922 E1.35591 *121
07:34:31.765 : ok 208
07:34:31.765 : N209 G1 X-6.677 Y-26.153 E1.36827 *115
07:34:31.780 : ok 209
07:34:31.780 : N210 G1 X-4.217 Y-26.661 E1.40357 *112
07:34:31.780 : ok 210
07:34:31.780 : N211 G1 X-3.346 Y-26.784 E1.41592 *119
07:34:33.231 : ok 211
07:34:33.231 : N212 M117 ETE 45m 41s *107
07:34:33.559 : ok 212
07:34:33.559 : N213 M105 *7
07:34:33.559 : ok 213
07:34:33.559 : N214 G1 X-0.842 Y-26.979 E1.45122 *121
07:34:33.559 : T:23.33 /0 @:0
07:34:33.574 : ok 214
07:34:33.574 : N215 G1 X0.079 Y-26.99 E1.46416 *99
07:34:34.323 : ok 215
07:34:34.323 : N216 G1 X2.546 Y-26.872 E1.49887 F900 *2
07:34:34.417 : ok 216
07:34:34.417 : N217 G1 X3.42 Y-26.775 E1.51123 *106
07:34:34.463 : ok 217
07:34:34.463 : N218 G1 X5.894 Y-26.341 E1.54653 *86
07:34:34.635 : ok 218
07:34:34.635 : N219 G1 X6.749 Y-26.135 E1.55888 *83
07:34:34.697 : ok 219
07:34:34.697 : N220 G1 X0 Y0 F4800 *99
07:34:34.869 : ok 220
07:34:34.869 : N221 G1 Z100 F1000 *37
07:34:34.916 : ok 221
07:34:34.916 : N222 M104 T0 S0 *3
07:34:34.931 : X:0.00 Y:0.00 Z:0.200 E:1.5510
07:34:34.931 : ok 222
07:34:34.931 : N223 M140 S0 *70
07:34:37.412 : TargetExtr0:0
07:34:37.412 : ok 223
07:34:37.412 : N224 G1 X0 Y0 F4800 *103
07:34:37.412 : ok 224
07:34:37.412 : N225 G1 Z60 F1000 *22
07:34:37.427 : ok 225
07:34:37.427 : N226 M84 *57
07:34:37.427 : ok 226
07:34:37.427 : N227 M105 *0
07:34:38.972 : N228 M105 *15
Here is the start of the G Code file.
generated by Slic3r 1.2.9 on 2015-08-23 at 07:29:45
; external perimeters extrusion width = 0.20mm
; perimeters extrusion width = 0.24mm
; infill extrusion width = 0.24mm
; solid infill extrusion width = 0.24mm
; top infill extrusion width = 0.24mm
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
G1 E-1.00000 F3600.00000
G92 E0
G1 Z0.200 F7800.000
G1 X-22.047 Y-15.521 F7800.000
G1 E1.10000 F3600.00000
G1 X-21.324 Y-16.548 E1.11765 F900.000
G1 X-20.774 Y-17.234 E1.13000
G1 X-19.082 Y-19.090 E1.16530
G1 X-18.450 Y-19.702 E1.17766
Yes, you are correct. Homing does set the multiplier back to 100%. I will upgrade the firmware to 0.924.
Thank You.
