x-y offset of print due to z-probe offset
Hello,
I encounter a problem with z-probe "grid" method.
My z-probe offset is x=27 /  y=-2. My extruder is at origin (x=0 ; y=0) (cathesian printer)
Before I used 3-point method, firmware 0.92.6, but I wanted to switch to grid method so now I use the latest 0.92 version.
When in the firmware, or Eeprom, I dial in the z-probe offset, the printer is printing with an x-y offset equal to the z-probe x-y offset. This means that the print is shifted 27 mm to the right. (Didn't check what happens on y axis)
I do not know if this is normal and if I should compensate for that. Also, I considered that the rotated plane takes the actual probe positions into account (ain't that the use of probe x-y offset anyhow ? ), so if I shift the bed coordinates, the plane shouldn't be correct anymore... ?
I did not have this problem in 0.92.6 with 3-point leveling...
Kind regards,
Frans
  • The offset is only used during probing and afterwards the extruder is selected again. Only command not always doing this is G30 where P parameter defines if that should happen or if more probes follow so you want to omit this step.
    I don't remember that this problem existed in 0.92. But the only version I would make changes on errors is the current version 1.0.4dev. So you should first upgrade to this version and see if it still exists.
  • Tank you for you answer. I have updated to 1.0.4 but now my z-probe does not work any more. Start script for servo is not executed. I get no error message on screen, nor on Repetier host.
    The sevro and probe  work on G30 though...
    I have tried setting probe offset to x=0 ; y=0 to avoid the issue of impossible to reach coordinates.
    Extuder is z-probe is false. (EXTRUDER_IS_Z_PROBE 0)
    Here's my configuration.h :
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_MIN_PWM 80
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 4000
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 30
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 757.64
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 19
    #define EXT0_MAX_START_FEEDRATE 13
    #define EXT0_MAX_ACCELERATION 500
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 10.14
    #define EXT0_PID_I 1.34
    #define EXT0_PID_D 19.15
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 0
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 0
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SET_INTERVAL 4000
    #define HEATED_BED_HEAT_MANAGER 2
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define HEATED_BED_DECOUPLE_TEST_PERIOD 400000
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_Z_BACK_ON_HOME 5
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 178
    #define Z_MAX_LENGTH 174
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 27
    #define DISTORTION_YMIN 0
    #define DISTORTION_XMAX 200
    #define DISTORTION_YMAX 178
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define STEP_DOUBLER_FREQUENCY 10000
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 1 // time in microseconds
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  1530
    #define UI_SERVO_CONTROL 1
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 5
    #define Z_PROBE_PIN 18
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 27
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 2
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 3.08
    #define Z_PROBE_DELAY 0
    #define Z_PROBE_START_SCRIPT "M340 P0 S560"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1530"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 30
    #define Z_PROBE_Y1 10
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 30
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 3
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 10
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Frans"
    #define UI_PRINTER_COMPANY "Middelkoop"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • > The sevro and probe  work on G30 though...
    All use same start script. So what commands did not work and what is the log for them?
    Also I saw z probe pin is 18 - is that same a Z_MIN_PIN? At least important for z homing.
  • I have switched back to 0.92.9 (also because SD card did not work anymore with 1.0.4)
    with the following change, it now works OK !
    I switched to Z_PROBE_Z_OFFSET_MODE 1 with Z_PROBE_Z_OFFSET 0 (probe measures coating level)
    before I had Z_PROBE_Z_OFFSET_MODE 0 with Z_PROBE_Z_OFFSET 0 , Maybe that messed it up as PROBE_Z_OFFSET_MODE 0  would need a value >0 ?
  • It's a RAMPS 1.4 so, according to the scematic, yes, pin 18 is Z-min.
    I'll give 1.0.4 another try a bit later (when back from work...) with the same change as above. Anyway, thanks alot for your help so far !
