Trying to customize the RS Touch frontend
Hey,
to be honest it's far beyond my knowledge, but still gave it a try.
I followed the instructions at (https://www.repetier-server.com/customizing-printer-frontend/) but got stuck when trying to compile.
It cancels with the following error message:
ERROR in Cannot determine the module for class MyDashboardComponent in /home/pi/Desktop/RSTouchscreenNG/src/app/mydashboard.component.ts! Add MyDashboardComponent to the NgModule to fix it.
To give it a first try I just deleted the "Restart UI" Line in mydashboard.component.ts and don't know what to do anymore. Hoping it's an easy fix someone can tell me how to solve it.
Any estimate when the next version will be out?
I tried to work my way trough a custom ui today (I admit: a lot of trial and error) and everything looked great until I came back to check a few minutes back and saw this error message:
Compiling @angular/router/testing : es2015 as esm2015
Compiling @angular/common/http/testing : es2015 as esm2015
Compiling @angular-redux/store/testing : es2015 as esm2015
Compiling pages : es2015 as esm2015
ERROR in main-es2015.js from Terser
Error: Call retries were exceeded
at ChildProcessWorker.initialize (/home/pi/RSTouchscreenNG/node_modules/terser-webpack-plugin/node_modules/jest-worker/build/workers/ChildProcessWorker.js:191:21)
at ChildProcessWorker._onExit (/home/pi/RSTouchscreenNG/node_modules/terser-webpack-plugin/node_modules/jest-worker/build/workers/ChildProcessWorker.js:268:12)
at ChildProcess.emit (events.js:198:13)
at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
[17:48:21] 'compileAppProd' errored after 3.85 h
[17:48:21] Error in plugin "gulp-shell"
Message:
Command `ng build app --prod` failed with exit code 1
[17:48:21] 'prod' errored after 3.94 h
any ideas? Else I belive I'll live with it the way it is or get someone to work out something that is 100% the way I want it.
I got it working now. Thanks a lot.
