After upgrading Host FolgarTech I3 Z axis not working.
2 nights ago i upgraded to 2.1.6. I do not recall the prev version but it is 3 or 4 gens old. I have a highly modified folgartech Leadscrews, wades extruder. It was tuned in perfectly... I am using marlin 1.1.6 I believe. and a SD card reader. I save gcode and print from sd card.
After the host upgrade my z axis attempts to run 30 or 40 times too fast and ultimately goes nowhere. I have changed every setting I can find. Does anyone know where i go to get my old settings back or what setting to work with to slow z....
Thank you.
Thank you.
Can you advise alternative settings. My printer has been down since I upgraded and I was printing COVID PPE...
and prototypes....
This code is getting added to all new files.
IF it is needed M201 Z needs to be 2 not 500
But I found where it stands. Printer settings->machine limits contains the values send in M20x at startup.
Thank you,
