Z axis home problem
I have a problem
My prusia i3
When i home it
It does everything right
It goes up a bit and the then it goes up again
It cant come down
  • Which software do you use? Host or server?
    In any case your z homing coordinate is set wrong in printer settings - you have it 0 while correct is higher (see prusa display after home). Enter that as homing z position and it will work I guess.
