Where are the config files with "End g-code" hidden? ;-)
After each script execution, my installation of Repetier-Host adds the following 3 lines of code:
line1=> M104 T0 S0
line2=> M140 S0
line3=> G1 X135.00 Y0.00 F4800.000
It is clear what the code does but I want to modify it so these lines are not executed each time I run a script.
These three lines are not in the Editable "End Code" Script.
Neither are these lines in the /Applications/Repetier-Host-Mac.app/Contents/Resources/defaultAppend.gcode file.
I deleted the app and tried deleting all configuration files before re-installing the Repetier-Host app. When that did not help I used:
grep -r "G1 X135" various_directories
... in terminal to find the file that contains parts of the three lines. Unfortunately, that did not work either.
I'm looking forward to understanding where I could find these settings.
Thanks for your help.
3DNewBe
3DNewBe
What I struggle with is the X value as it needs to know how wide the printer bed is. The X135 can not just be a random value so where is it calculated. I'm new to this and in the discovery phase of how 3D printing works.
Thanks a lot for your help.
So logic once you think of it. Thanks for pointing that out.
So it should be by the Repetier-host app itself. I do not use Repetier-server yet.
- So if not in the Editable "End Code" Script and
- and in the /Applications/Repetier-Host-Mac.app/Contents/Resources/defaultAppend.gcode file
where else could such code be stored?Any ideas? Thanks for your help!
Thank you so much for your help. It is much appreciated.
https://www.repetier.com/w/wp-content/uploads/2012/08/rhm-printer-settings2.png
settings referred to by Repetier are:
[ ] Go to dispose after job/job kill
[ ] Disable extruder after job/job kill
[ ] Disable heated bed after job/job kill
All three need to be unmarked to avoid these lines being added to any script being executed.
