Manual XYZ controls don't work from android chrome
I have noticed that after a print the manual controls in the web UI behave really strangely. Sometimes they don't work at all, sometimes they just do unexpected things. Not sure if this is a firmware thing or a server thing. By strangely I can give an example, after printing something I can home all the axis, if I then try to raise Z the X and Y axis move close to the middle of the print area and then finally Z raises. When this happens the location of X and Y are not updated in the UI but homing all axis afterwards shows that the firmware knows they moved because they go back home. Not sure if this could be related to me not using endstops of any kind. I have checked logs on the server and see noticed nothing out of the ordinary. Also, when the manual controls are not working at all from Android they do work from a desktop browser which makes things even more confusing to me. The extra XY moves also seem to happen from the desktop broser as well, and again the XY gauges in the UI don't reflect that they are actually moving(they stay at 0 and only Z goes up, but all 3 axis actually move).
Please help me troubleshoot if you have a few minutes, none of these problems are showstoppers but they are minorly inconvenient.
Will update with my new findings shortly.
Its kind of funny because you can fight with it by doing manual moves and it will make the manual move then go right back to finishing the print, still not showing a running job.
